Pride Victory 4 Wheel Mid-Size Electric Scooter  Logo
T
Tim Calhoun Posted on Oct 15, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a victory pride 4 wheel scooter runs great I have a problem though I leaned over to pick something up and now it will not go. plenty of charge lights and horn still work and meter on steering wheel still shows fully charged. is there a trip switch if it thinks it is turning over?
Dan Hudson
Level 2:
New Friend:
  • Expert 119 Answers
  • Posted on Oct 16, 2013
Dan Hudson
Expert
Level 2:
New Friend:
Answers
119
Questions
0
Helped
80342
Points
206
There is no tilt switch. It can time out though, but just turn it off and on again.
5 Related Answers
Anonymous
  • Posted on May 13, 2009
SOURCE: pride victory Scooter battery charged won't run
Its probably too late to give my opinion, but here goes anyway.
I had a similar problem with my mothers scooter and it turned out to be a faulty connection on the wires leading to the motor. I simply pulled the plastic connection apart, cleaned and lubricated the contacts, refitted the connection and all was well.
Lee Glascock
  • 384 Answers
  • Posted on May 24, 2009
SOURCE: dead and wont move cant charge but batties are ok
sounds like a dead battery on the unit. see if you can get it replace .
Anonymous
  • 3085 Answers
  • Posted on Jun 18, 2009
SOURCE: Forward/Reverse switch not working Revo Pride
Could it be in free-wheel mode. Most Prides have a pull up knob at the rear of the scooter.
oregoon
  • 175 Answers
  • Posted on Jul 09, 2009
SOURCE: I have a pride victory xl8. Problem - was running
All scooters have a protection system built in to prevent burning up the motor, and the user, should the scooter overheat. It sounds like yours overheated. If the temp. outside was warm to hot, and your weight is near the weight limit for the scooter, and you are taxing the motors over a hill, or unstable terrain, then the scooter goes into "limp home mode", or just enough to get you a bit aways, and then it will turn off. After a few minutes to cool off, it will go again, but shut down fairly quickly because it takes a spell to let the whole transaxle-motor assembly to get cool.
Check your weight, and anything else you may be carrying with you on the scooter. Check the terrain, and incline you are going against. Throttle down for all these occassions. If you overloaded the system at some point, then you may have overheated the brushes. Remove them (2) with a standard screwdriver and see if the copper coil is still flexible and springy. If not, replace it/them.
The damage may already be done, so it may need a new motor/transaxle assembly. An expensive proposition I'm afraid.
gewiz
Rob Hill
  • 1480 Answers
  • Posted on Oct 01, 2009
SOURCE: Pride Legend scooter won't hold charge
check the wiring from the batteries as a wire could have come loose.
Regards
GeWiz
Pride mobility victory XL front tyre wear
Is your track rod bent or out of alignment? Carefully buy the exact wheels with tyres and a track rod if necessary from dismantled Victory XL scooters (a good wheel with a good tyre about €30 - I've done that for my Pride Celebrity XL8 - it was a great success.
My pride mobility victory scooter will not charge
You must charge each battery individually with an automotive NON automatic style battery charger until each battery has at least 10 bolts each. The scooter charger cannot pull up a battery with less than 10 volts.
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
1helpful
2answers
Scooter is running slow
Have the batteries tested with a load tester. Usually when it starts to move slow it means the batteries are going.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
