Question about GE 27980 Cordless Phone
Radio buzzing noise
My radio has a pulsating buzzing noise so I can't even hear the audio of the radio. How do I get rid of it? I've tried moving the radio different directions, but no help.
    Habit-Forming:
  • 138 Answers
Your radio has a bad speaker. Need to replace.
Posted on Oct 15, 2013
SOURCE:
Bang & Olufsen Beosound 3200 CD Door won't open
Could be the PCB9 light and motor control have the problem its on the upper left side of the player.
Feb 25, 2013 | Audio Players & Recorders
Samsung makes buzzing noise, gets louder when volume is higher
you may be hearing a buzz from inside the set---it is not rare for a transformer or other part to vibrate hard enough to produce this kind of sound.
Another common cause is the surface the set is sitting on===if hard and not fully supporting the set evenly this can cause this problem also.
On a set like the one listed here it is likely coming from the power supply but can be from other areas as well.
May 25, 2012 | Televison & Video
Buzzing sound when sub is on even without turning my amp on, if you can call me on my phone 909 938 9219 it be better for me thanks, i am little slow with my computer, please help
Buzzing is usally AC line noise leaking into an un-shielded cable somewhere or a floating ground. If the AC plug is reversible, try that. Sometimes the buzz is from an attached device. Make sure all audio cables are plugged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's.
Disconnect the input(s) and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights.
I've also seen variable track lights induce noise but it's usually minor.
Try rotating the power cord in the wall outlet.
If it still buzzes with no cables or anything external attached there's an internal problem.
Apr 30, 2011 | KEF Audio PSW 2150 Speaker
I have a JVC (stereo, radio, cassette, recorder) and it's buzzing
If it is only when the tape is running, it could be motor noise.
Worn bearing in the motor or maybe a suppressor has failed, if it has one.
Oct 09, 2017 | JVC RC-EX25 Radio/Cassette/CD Boombox
I paid a store to hook up my lanzar vibe 241 amp and 2 lanzar 12" subs(all brand new). It sounds ok but i have a loud buzzing coming out of it constantly and when i use my power window buttons I hear a...
To get rid of the buzzing sound just go to walmart and in the car stereo section buy the $10 rca ground loop isolator, this is the best way to get rid of amp noise
Oct 11, 2009 | Lanzar VIBE241 Car Audio Amplifier
Buzzing noise while making a call
This happens at many phones due to the speaker which buzzes because of the waves made by the conversation. For example try calling someone and be near a desktop pc speaker or radio and you'll hear the same buzzing noise
Feb 19, 2009 | LG Dare VX9700 Cell Phone
Buzzing Noise in Sound Studio
hi, check all cables,clean connections. i have had these kind of problems in the past. also coulb be ground loop!? hope this is helpful.glen
Feb 15, 2009 | Apple Griffin iMic External Sound System
Buzzing noise from speakers
The buzzing noise is being heard probably because there is another electronic device around that's using radio waves to function. (Such as a cell phone, a cordless phone adapter or a wireless router. Even microwaves and ceiling fans can give off these sounds.)
My advice would be to try and move around or turn off some appliances in your room that may give off radio waves.
Sep 18, 2008 | Logitech Z-2300 Computer Speakers
Distortion/noise and buzz in front left speaker
Try to see if the reciever will make the buzzing/noise without anything connected to it except power, and speakers. Tune into a local radio station and see if the noise continues. If the noise has stopped, then you know there is an issue with the player or cable.
Dec 28, 2007 | Onkyo TX-SR503 Receiver
GE 27980 Cordless Phone Logo
136 people viewed this question
Top GE Lands Phones Experts
martin hogg
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
