Question about Water Dispensing & Filtration
What well supplies will I need to set up a well I can use on my property?
    New Friend:
  • 50 Answers
You will need:well
pump
water
storage (pressure) tank
distribution system
treatment system (if necessary)
You can find more info here:
http://www.gov.ns.ca/nse/water/docs/constructwell.pdf
It's for Nova Scotia, but it should still be relevant since a well is still a well.
Posted on Oct 15, 2013
SOURCE:
My printer has been altered by grandchild now it wont print colour, need to return to factory setting
Try going to printer property's, on the top selection bar select effects an untick the monochrome effect box if that does not work the put the printer make/ model number on as every printer has its own way of doing things .
Feb 03, 2018 | PRINTER Office Equipment & Supplies
Good day I am seeking for an assistance I need to change the status of an Epson lx350 printer on standard mode to be on HSD/Draft/Roman or Sans mode
The printer settings for the document are set in the document, not the printer. When the document is formatted the print style (font) is set and in the printer properties you should set for draft or standard mode
Sep 01, 2017 | Epson Office Equipment & Supplies
NO-how to chg printer to print from top to bottom -not side to side
Hello
It sounds like you have a dot matrix line printer. i would check the printer properties of your printer. I believe there would be a setting within these properties that will show which direction you can print. Just click on the right setting for your job.
Jul 15, 2017 | PRINTER Office Equipment & Supplies
Memory is low - job cancelled on LaserJet Pro 400 message
you have jobs stored in internal memory you need to remove these before you start new job. the firm ware software will have the the wipe settings in the settings folder in software, aldo check in device properties for device that it has full use of the memory of the device some are set to 20mb put it on its highest memory setting.
Jun 22, 2017 | Pro Office Equipment & Supplies
Epson TM T88iii printer not printing
Since you are using the USB-to-serial converter, you need to select the serial interface in the printer driver installation.
  1. Uninstall the driver in Control Panel > Add or remove programs
  2. Restart the computer
  3. Install the printer driver again, this time select serial in the interface list
  4. Set the properties for the serial port to 9600 for the data rate
  5. Print a test page!
Sep 07, 2017 | Epson TM-T88III Thermal Printer
How to lower screen resolution on safe mode
Good day!
Right click in desktop > properties > pop up display properties > click on settings > advance > adapter > click list all modes
select the display you needed for your pc.
Have a good day!
visit HPParts us Computer Parts Power Supplies Electronics Hard Drives...
Aug 08, 2013 | HP Pavilion F1523 15" LCD Monitor
Lock wifi so anyone that wants to use it needs a password
go to wireless network properties and set the network authentication to shared key. then supply the network key you like. email me so i can help you if cant find it. jasonperez_1@msn.com. i am more than willing to help you
Jun 24, 2012 | Trendnet TEW Computers & Internet
I have very low resolution.
Hi betty2293,
Low resolution on your desktop can be for two reasons ,
  1. You have chosen a low resolution from your desktop properties, you need to check this up , by right clicking anywhere in a free area of your desktop , then selecting properties --> settings tab and then you find an option to change the resolution.
  2. If you don't find multiple options to select that means, it's because of no video drivers installed.
  3. Therefore you need to use your motherboard supplied CD to install the VGA/Video drivers and things should work fine for you and you will be able to find multiple resolutions in your settings tab which I described above.
Hope this helps...:)
Aug 23, 2011 | Computers & Internet
How does one set the 1440 X 900 resolution on the V193W Acer LCD Monitor
Right click on your desktop and select properties, then select the Settings tab and you'll be able to adjust your resolution there. Your graphics card/driver will have to support the resolution you desire.
Mar 27, 2009 | Acer V193w LCD Monitor
Water Dispensing & Filtration Logo
451 people viewed this question
Top Water Dispensing & Filtration Experts
ray gallant
ray gallant
Larry
Tom Chichester
Are you a Water Dispensing and Filtration Expert? Answer questions, earn points and help others
