Check the belts, inside the unit you should see a rubber belt which is what pulls the tape fast forward or rewind. Some belts with time get loose and slip, they can also break and fall off which will not let you fast forward or rewind.
Open your cassette player and look where the plastic pulleys are located and check for the belts, they might not be broken at all but very loose and slip on the plastic pulley.
I may not have worked on one of these before but all tape decks have some common drive parts. Yours is missing the proper torque to drive the reel table in take-up for play and your fast wind observation also points to either drive transfer problems or the motor itself. I suspect the fastest answer is to have a tape deck technician work on it. Dual cassette decks are not known for being the long lasting products like a singles cassette deck is.
something maybe broken on the inside for it to say play but fast forward. the botton could be stuck as well. maybe open the vcr and clean it all up in side. that might help
Cheap cassette players have no rewind feature. This allows the mechanism to be simpler and cheaper; they just 'pull' the tape forward constantly, without the pinch wheel for "fast" [sic] and with the pinch wheel for "play".
To work out if this is the problem with your cassette player, look inside with no cassette inserted. If one of the spindles is plain, without the "three-pronged" device to engage with the spool, then you have the cheap device with no rewind. Turn the tape over, and fast-forward.
Hi, Does the tape move when you press rewind or fast forward. If the tape moves for a few seconds then bleeps it sound like a sensor problem. If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward. Hope this helps.
check to see if it fast forwards or rewinds. If one or none of these work, the drive belt has come off the cassette drive motor and it needs to be taken to a repair shop
