Question about VXI Corporation Blueparrott B250-XT Bluetooth Headset
The unit works on every thing but can hear the people on the other in end.
  • 416 Answers
Please be more specific.
Posted on Oct 15, 2013
Testimonial: "The unit works fine in every fashion but I cannot hear the people on the other end. The other people can hear me just fine the volume switches go up and down according to the phone. The unit will answer or disconnect fine. The unit will pair up fine."
SOURCE:
How come people can't hear me from my headset?
Volume only has to do with the sound level you hear.
The only thing that affects the sound the other ends hears is the microphone, Have you tried moving the mic? Has the headset ever worked properly?
If the other end hears you at all, then the headset SHOULD NOT be muted, but it's worth checking out. They put the mute switch on the underside of the boom mic and sometimes people hit the switch by mistake when moving the boom.
Aug 17, 2014 | Plantronics Voyager Legend
My nuvi 275 doesn't have sound
ok a few things to figure out here, Sound..you cant hear any street names, or music
If its street names you must chose a language that has an ending ( TTS ) text to speech
do that by going to Tools.... Settings... Language... under Voice pick one with an ending ( TTS )
next we will try any other sound... is it muted? on main screen press Volume Icon
doe sit have a checkmark in MUTE? if so remove it
If not then on that screen there is FM Trans on bottom of screen .... press it
Enable FM Transmitter if it has a checkmark remove it...... place a checkmark there if you want to hear your unit thru your car speakers
Nov 05, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
I have a Nokia 6015i cell phone. When I call somebody on my contact list, they can hear it ring on their end but I can not on my end. I can hear it ringing if I use my loudspeaker. There is an...
When you make calls and people hardly hear you, It means that the earpiece which allows you to hear
people that is located at the top of the phone if faulty and needs to be replaced with another one.
When you replace,will work again.
Have a nice day.
Aug 09, 2010 | Nokia Cell Phones
Speaker phone problem
It is possible. I have ATT 945(?) 4 line phones that communicate via a DSL-like signal between units to do special things like intercom, etc.
What I have in my setup is that I have a seperate line from the point of entry of my phone line to my DSL modem.
I then have TWO stacked DSL filters PER LINE that feed the main phone line running to all the phones.
Be AWARE that when using the speaker phone there is a modulation of the gains both directions. When you talk OR have a noisy background noise, the gain of the speaker is cut down to prevent feedback. And when you go silent, the speaker gain is increased for you to hear the other side of the call. Essentially it takes as much discipline as the old two-way radios... one talker at a time with these speaker phones AND very little background noise.
Jan 09, 2010 | RCA 25425RE1 Phone
My high end stopped working in both my speakers
First thing is to run a known signal from a simple device like a small CD player to verify the problem.
If these are driven from a mixer, the EQ could be set to kill the highs.
Assuming it isn, something simple like an EQ setting, probably the units will have to be serviced. I know you would already have checked the EQ on the back of these things as a first step.
Remember to ALWAYS power these from the same source as the devices connected to them to avoid ground loops and damage.
Supersonic feedback can fry these. Oscillations higher pitch than you can hear can put too much power into the tweeters of these.
Nov 18, 2009 | Mackie MR5 MR5 Reference Monitor
Blackberry Pearl I can not hear any thing on my end and the
Please check the volume of you're Handheld still if it is not working, You need to walk into the service center to check the speaker's of you're Handheld.
I hope I was able to help you.
Thank you for using Fixya.
Oct 21, 2009 | RIM BlackBerry Pearl 8100
Uniden cordless phone 900 MHz
A phone uses a voltage drop to determine when it is answered or hung up. What is happening in your case is the phone or base unit, or worse yet the house wiring has a short to ground somewhere. This also cause the static you hear. You can get a regular phone and plug it into the same cord and see if it works normal. If so it is not the house wiring but the phone or base unit. If so you can only hope to find the short yourself which is very time consuming and difficult on modern digital units. Sorry to say it's cheaper to get a new unit than pay for repair. The only other thing that cause those symptoms is the batteries are going dead. I assumed you checked this first. If not you can try changing the battery pack on the phone.
Mar 28, 2009 | Uniden Cordless Phone
Sound gets cut off quite frequently on one end
Could be caused by feedback from the speakers being to high in volume.
Hope this helps. Bud
Apr 25, 2008 | Logitech QuickCam Communicate
Phone speaker inoperative
I still have this problem as I stated on the 24th April .
I am hoping someone will respond to it.
Batesie
Apr 24, 2008 | O2 Xda II mini
Headset mic doesn't work
Disconnect the all lines and power
Remove battery of the headset
Put battery back in
Connect phone line
Connect power cord
I am trying this according to Thomas 800-511-3180
Jan 16, 2008 | RCA 25110RE3 Phone
VXI Corporation Blueparrott B250-XT Bluetooth Headset Logo
53 people viewed this question
Top VXI Corporation Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a VXI Corporation Radio Communication Expert? Answer questions, earn points and help others
