www.automotiveforums.com > ... > Daewoo > Nonspecific Oct 11, 2004 - Radio Code List: Nonspecific Car Forums. ... DRacer. 12-05-2006, 06:26 AM. Hi ... Suzuki Forenza 2004. the radio code 4316 worked for me.
? 2:37 www.youtube.com/watch?v=LfB98cNLXn0
Jan 24, 2011 - Uploaded by 05Forenza
Just a quick video/overview of the stock radio in the 2005 Suzuki Forenza. The stock stereo consisted of a ...
answers.edmunds.com > Edmunds Answers Sep 15, 2008 - every so often it will if i hit the right bump ... I'd guess that this is a problem in the trunk itself, with the switch that activates the light. Press up and .
If there is heat and no fan (turn on heat and hold your hand next to the vent) then it could be the fuse in the engine compartment. I just fixed mine for $6.00
You should probably start by changing the bulbs. No... they didn't both burn out at once. You might have driven a month with only one, and didn't notice untill the second one went. Just check in the socket with a test light. If you have power, you should have lights. If you don't have power, your switch isn't as good as you thought, or you checked the wrong fuse.
Check if the kill switch is engaged. Check for faulty starter solenoid or disconnected solenoid wire. Check for defective ignition switch. Check for defective starter motor.
as far as I can tell from all the posts (and i have the headlamp problem w/ my '05) is that there is a well known problem with that, and was also recalled for defective wiring...
