Hi, My washing machine is going through the full wash cycle and then freezing on the spin cycle. This means it's not draining. What can I do to fix it? Should I check the pipes arn't blocked? Is there anything I can do to drain it manually (the waters starting to smell)? Cheers Matt
Drain pump filter may be blocked.
Had the same problem. Machine would freeze on drain / spin cycle.
Filter had caught 4 coins but a hair clasp had got past the filter.
When all coins and clasp removed machine all back and working.
Very easy job. Remember to use the flexi pipe to empty the water first before undoing drain plug or you will get a very wet floor.
Check your lid switch
Problems
with a washing machine not spinning or not draining are often inter
related..
If you are having a problem with your top load
washer then check out this tip...
Washing
Machine
does not Pump or Spin
If you are having problems with your
front load washing machine then checkout this tip...
Front
Load Washing
machine not draining and or not spinning
heatman101
