Sony Bravia KDL-40V4100 40 in. LCD HDTV Logo
N
Norm Posted on Oct 14, 2013
Sony bravia 40 brightness control not working
Sanjay Pal
Level 1:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 37 Answers
  • Posted on Nov 24, 2013
Sanjay Pal
Contributor
Level 1:
Cheetah:
Answers
37
Questions
Helped
9055
Points
45
Try to reset the tv first from set up menu. then check the brightness control working properly.
5 Related Answers
A
Anonymous
  • Posted on Apr 27, 2008
SOURCE: Sony Bravia 40" LCD TV generating heat.
First, you will have to define what you mean by "hot to touch" ie.:
can you or can you not hold your hand on it for a few moments.
Anonymous
  • 210 Answers
  • Posted on Oct 01, 2009
SOURCE: My SOny Bravia 40 inch LCD TV has a vertical line
It could be 1 of 4 things:
1. One of the ribbon cables has worked itself loose (Simple Fix)
2. One of the assembly boards maybe faulty
3. The driver board which feeds the panel maybe faulty
4. The panel is faulty
The driver board in the UK costs approx £70 and approx £35-70 to fit it if this is the fault.
All other parts are between £80-160 and approx £35-70 to fit it if this is the fault.
The panel will cost approx 50-75% of what the TV was worth when you bought it - "Repair versus Replacement"
Thanks
Anonymous
  • 616 Answers
  • Posted on Dec 30, 2009
SOURCE: the volume control is not working on the Sony
Call Sony
Anonymous
  • 159 Answers
  • Posted on Mar 30, 2011
SOURCE: sony bravia led 40" blue
That actually happened to a tv of mine once-i had some clear diet soda get spilled on front, I didn't clean it out(just off of screen) and I corroded the contacts on the lcd itself. if it is a recent problem get it cleaned/clean it yourself as soon as possible to prevent damage to screens connections. hope this was helpful, good luck. Prodzilla
Jeancarlo arias
  • 40 Answers
  • Posted on Jun 29, 2011
SOURCE: Need a manual for our Sony 40" Bravia 3d tv.
You could find the manual here http://www.docstoc.com/docs/63734879/HDTV-User-Manual-Sony-KDL40HX800-40-inch-1080p-240Hz-3D-Ready-LED-Backlit-LCD-HDTV--Sony-BDP-CX7000ES-400-Blu-ray-Disc-Mega-Changer-_Black_ ... Hope this helps
Why is sony bravia dark screen
If your TV seems to be darker than you think it should be, it is possible that the problem is with the light sensor. The light sensor will automatically adjust the picture brightness based on the ambient light that is in the room, (i.e. if the room is bright the picture will also be bright, if it is dark the picture will also be dark).
To turn this feature off go to Settings > General Setup > Light Sensor.
What are the ideal picture settings for Sony Bravia TV model #KDS-60A3000?
depends but for me a sony has a softer picture brightness so the parameters are contrast/picture 80, brightness 50,color 60,sharpness 40/20 try this charley
1helpful
Bright light ghosting and vertical and horizontal line on Sony Bravia 40
This is a problem with the inverter cable. It either needs to be re-seated or replaced.
1helpful
My Sony flat screen bravia hdtv 40" when i turn it
Your LCD TV needs repair,abnormal display caused by a faulty LCD Control board. Replace the control Board.
My Sony Bravia KDL-40S2000 has a bright blue-green line right down the center of the flat panel. Can it be fixed and is it expensive?
this means loss of pixels. the display panel is either bad or damaged. your warranty should take care of this problem if it is still under warr...
Picture get dark than light
On your remote control, press the huge circle, which should be settings or menu, there, go on brightness, put it up to max if u want bright, and low if u don't .If the problem still happens, ask customer service to help, or return it!!
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
