First Option: mostly nokia chargers doesn't make problems... just try the following.. connect ur mobile with a system (usb cable)... found out whether it is charging or not... if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)... if it charged with usb cable buy a new charger Please change Phone Bettery and check the charging IF Charging Problem not Solved So
Second Option: Your Phone charging IC Fault So Please change charging IC And charging Problem will Solved Quickly
The manual should load straight away. You can download it to youcomputeras well. If you can't see anything you may need to download a PDF viewer such as the one below.
Hello, Todownloadthe msnmessengerclick theaddressbelow,thefileisinZIP format, you mustunzip it,sendtophonethroughusbdata cableor usingthememory card,if you havezipin thecellcangoto theaddressfileviaInternetphoneand downloaddirectly toyournokia.
If youdo notknow howto unpackandinstallI amavailableto answer any questions. http://www.symbianv3.com/files/WindowsLive_for_Series60_3rd.zip (copy and paste on browser PC or mobile) Thislinkyou willfindalternative applicationsfornokian96.
You can just change the whole look and display of your nokia n96 phone but you cannot install windows phone software. You just have to download and install software in which you are interested But it could slow down your phone performance.
