You'll need a ruler :-) and to choose a mount for your TV size of 32" bearing in mind the weight:
Which mounts will fit my TV
SOURCE: LC-32d40U Sharp Aquos Screen shows "please wait" controls do not respond
Hi.
Im not familiar with your TV set as it is made for USA but here in the UK some sharp models suffer with similar problem & this is the remedy.
As I said I cant gtee it will sort your problem but give it A try.
SOURCE: Wall Mount won't fit screw pattern (405mmx200mm
for $19.99 you can get an adapter. Do a search for TV mount adapters 200x400 on amazon, or tiger direct, or the shopping site of your choice.
SOURCE: I NEED A WALL MOUNT FOR A 32" tv
Wall mounts use standard mounting configurations, you should be able to get a wall mount for a 32" flat panel TV at any local electronics store.
SOURCE: Sharp Aquos LC-C3242U power issues
Do you get any indicator lights at all, if you do, then the 5v standby circuit is working, if you get nothing at all, then the main power supply will be the first palce to look, blown fuse? capacitors?
SOURCE: Hi. I need the 4 screws to mount the TV stand to
They are metric screws, you van get them at Lowe or HD, try M5 or M6. they are about 35cent each so you can try difference length.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Vesa standard (300x200mm)
Screw type: 4 x MB5x10
here's my search results:
http://www.google.com/#q=300mm+x+200mm+wall+mount+bracket&hl=en&prmd=ivns&source=univ&tbs=shop:1&tbo=u&sa=X&ei=yjx5Tf2vJZKw0QHL-ZzMAw&sqi=2&ved=0CFMQrQQ&biw=1015&bih=642&bav=on.2,or.&fp=86eb73c4baae05b0
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
