I need to match is a ATI mobility radeon hd 4670 vg.m 9606.12 it is not avail anywhere. There are a number of similar cards out there but I am not sure they work on my Gateway zx6810. What I was hoping for was to find the spec's on the card that I have so I match them to a replacement card that would be avail. Thanks
SOURCE: support for wide screen monitor
1600 × 1200 32-bit color is the maximum resolutions of u're video card. And the native resolution of the monitors is the highest resolution supported by them, so there is no worry, u can use the video card u have ... !
http://support.gateway.com/s/VIDCARD/VisionTEk/6002239/6002239sp3.shtml
SOURCE: Suggestions for new graphics card on Gateway 300s
just check what motherboard version your computer is running on and just advise the supplier to supply you with a graphics card that well fits for that motherboard.....
SOURCE: Would like to upgrade Gateway Desk Top 500SE to a HD video
I don't think you can't do that without some major changes. The 500SE is a small format computer. The motherboard only has 2 PCI slots so you need to match that interface. NewEgg still sells the PCI video cards but I don't think they are HD
http://www.newegg.com/Product/ProductList.aspx?Submit=Property&Subcategory=48&Description=&Type=&N=2010380048+1069609642&srchInDesc=&MinPrice=&MaxPrice=&PropertyCodeValue=696%3A9642
You need a more larger power supply. The current one is a 145 watt u-ATX Form Factor; you need at least 250 watts in that form factor (size)
A better choice might be a new motherboard. Look for board with a AMD Socket 7 if you want to keep this CPU. The motherboard will need to match the size of the current one to reuse the case. It's a uATX "like" form factor (7.4" x 9.35"). Also plan on a new power supply any AGP or PCI-e video card will want more than 350 watts (for the low end cards). Getting a new computer might be worthwile.
I hope this helps.
SOURCE: I installed pinnacle 14 hd studio in my son's
I had the exact same problem when I installed my Radeon 5670. I fixed it by going to device manager, video adapters, update driver (let it search the web and install). Worked fine after that. Good luck!
SOURCE: P 172s fx laptop graphic card replacement?
Unless you are an electronic engineer you won't be able to do anything. The graphics is onboard.
The only card that will fit in the Gateway ZX8600 must look like this on the back of the card. The 4 holes on the front must have threaded inserts that allow for screws.
Add a CommeThe only card that will fit in the Gateway ZX8600 must look like this on the back of the card. The 4 holes on the front must have threaded inserts that allow for screws.nt
