My ezspa is set for 102. Every time the temperature reaches 97 degrees I get a 104 degree light on and continues to flash when the water temp is really 97. I reset it continuously. When it flashes 104 I loose all control of the control panel. Unable to turn it off or turn the light on or off.
If you can contact your spa manufacturer they will usually send you the manual for your unit at no cost.
If the temperature is set at 104 it is at the high end of the safe temperature for a human. 102 is recommended, and 103 is OK for 15 to 20 minutes maximum.
If your spa is actually at 118 degrees, it could easily cause very severe medical heat distress. I would strongly recommend NOT using it until you can get the temperature down.
It's possible that the blinking light is a warning.
need more info. will temp lower? if temp lowers try setting up to 104 if desired temp will not increase sounds like you need temp adjustment switch if desired temp goes up to 104 but water doesnt sounds like temp sensor if temp sensor is good heater element
If the heater is set to 104 then this is probally your Aqualink temp sensor. This is mounted in a pipe with a stanless steel clamp holding it in place. If you follow the wire back to the controler box it just unplugs and the new one goes right back in. Easy to do and the part is inexpensive.
When you alter the set temperature via the keypad the display will flash the temperature thats to be acheived, once it stops flashing the keypad will revert back to the current temperature of the water.
