SOURCE: singer ce100 start button
Yes I am trying to use the embroidery unit when the start button won't work...it works up to the point of pressing start to embroider. The design is sent and ready to go.
Thanks Vanessa
SOURCE: Singer Futura CE100 Connect Error. Check that USB cable is connected and power switch is turned on.
I received an email back from Singer stating that it is not possible at this time to load the Futura software on a 64-bit system using Vista. I have emailed to ask whether it would load if the OS were XP, but I haven't heard back yet.
They said that they were working on finding a fix for this, but they aren't sure that they will since it's a hardware problem.
So here's what I did and it worked for me. Somehow the WinDriver that is on the software is uninstalling itself and needs to be listed with the drivers for Jungo for this software to work. I installed the software when I first got the machine with no problems, then suddenly I couldn't open it and was receiving the same connection error. When you go to http://www.futura-support.com/faq/machine.htm#2 to install the drivers, you'll notice their screen shot shows both the CLEM driver and the WinDriver. Check your machine following their instructions to see if you have both listed under the Jungo driver. If not, go to http://www.jungo.com/st/windriver_usb_pci_driver_development_software.html and select the link under "Available WinDriver Toolkits" for your operating systems (I selected WinDriver USB for Windows). It asks a bunch of questions which I didn't know the answer to so I selected "other" on almost everything then entered "NA"or "?" for the other description. Select Download now and it will need to restart your computer. Once done, I looked at the device manager again and now WinDriver is listed under Jungo and CLEM and the software opens, no problems.
This will at least temporarily solve the issue, however, it's a free trial which means the download will expire at some point. Good news is, the windriver is on the futura disk, I just don't know why it's not installing or staying on the machine. I am sending all of this to Singer to figure out what they're missing in the installation files and hopefully get a fix permanently.
SOURCE: singer futura ce100 windows 7 driver
Found this on the web. Hope it answers your question Futura link
SOURCE: Where to purchase Futura CE100 (2.5 Upgrade program
try these sites
http://www.sewingmachinesplus.com/Singer-Futura-Upgrade.php
http://cart.jennys-sewing-studio.com/index.php?main_page=product_info&cPath=72_77_82&products_id=222
http://www.sewamazed.com/futura-upgrade-2.html
http://www.futura-support.com/products/ce-100/software
Testimonial: "I haven't ordered the upgrade, but will buy after the holidays. Thanks "
