SOURCE: fuse box
The main fuse is under the panel on the right side behind the forks and the rest of the fuses are in the crank case under the cover...where you fill the oil.
SOURCE: 2001 suzuki 1500 intruder won't start. replaced
Could be a bad starter push button,poor connection in wiring, bad safety switch.Need to track down with voltmeter if you can.
A good dealer may offer some help if you buy the parts needed from them.
SOURCE: Suzuki intruder 1500 charging system
You need to buy a volt meter and set it on 10, or 20 v-. Start the bike and see what it says. A good charging system will show 13-14+ volts. If the meter says 11-12 volts or does not change, you have a bad stator, or rect/reg. Take to a shop to have it further tested. Chaz Moto DC
SOURCE: I have a 2000 suzuki intruder 1500. When I turned
could be a bad connection to the battery or the starter solinoid cant think how to spell it but its where the positive battery wire hooks up
Testimonial: "Thanks for the information, sounds like it could be a loose connection. Where do I find the starter solenoid ? "
SOURCE: how to adjust clutch 1998 Suzuki VL 1500 intruder
The clutch on this model is hydraulic and is 'self adjusting", if the clutch is slipping the plates are worn out and in need of replacement. This information comes directly from the factory service manual.
