Re: hotpoint condenser dryer drum workinbg no heat
Check the temperature switches in the back for continuity and also the moisture sensor on the exhaust housing at the rear of the unit. all these switches should be normally closed.
good luck...jay
Hi, Well if it is getting hot but not drying the clothes than most likely you have an airflow problem. Take off the vent hose on the back of the dryer. It will be plugged up with lint either inside that vent on the dryer or the hose will be plugged somewhere. If you clean this or just plain replace the old hose this will take care of the problem. Good Luck. feed back is appreciated.
you will need to remove the drum for this one. once it is out, the element is mounted on the back of the unit. not a hard repair, just lay out the parts as you take it apart to give you some order as you re-assemble it.
Probably open circuit heater element, or thermostat/s
Remove top cover, and you will see the heater manifold on the top of the drum.
It is a long aluminium box.
The element and stats are located here..
You will need a meter to test the appropiate components for continuity.
Please rate my solution.
Thanks.
Check your rear exhaust vent for blockage.
Your dryer has 2 heating elements.
If it gets warm at all at least one element is broken.
The operating thermostat could also be bad.
Burned/broken wire at heater terminal.
Unplug the dryer.
Remove the front panel, then the belt and drum and inspect the heater and thermostats.
