Broksonic CTGV-5463TCT TV Logo
Posted on Apr 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Who makes Broksonic tv ?
The manufacture. I am trying to program a universal remote control using this brand T V . I have tried four different universal remotes and can't get any to work. I see the brand name on the list but none of the codes work, nor does the code search application.
Grand Canyon Tech
Level 3:
  • Broksonic Master 3,867 Answers
  • Posted on Apr 23, 2009
Grand Canyon Tech
Broksonic Master
Level 3:
Answers
3867
Questions
Helped
1177139
Points
12717
Can you plese visit this website http://www.broksonic.com/
there the manufacture. you may want to call them for the current codes not all codes are garanteed to work thanks.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
  • Grand Canyon Tech
    Grand Canyon Tech Apr 24, 2009
    I gave you the website why was this not a help to you can you rate one notch up thanks
55' polaroid tv & rca universal remote I can put code in for the menu to show up & it won't let me program reset or scan for channels or change cable to antenna nothing what am I doing wrong
It sounds like you may be having trouble programming your RCA universal remote to work with your 55" Polaroid TV. There are a few things you can try to troubleshoot the issue:
  1. Make sure you are using the correct code for your TV. RCA universal remotes come with a list of codes for different brands of TVs, so you will need to refer to the instructions for your remote to find the correct code for your TV.
  2. Try manually inputting the code. Some universal remotes require you to manually enter the code for the device you are trying to control, rather than using the automatic search function. Refer to your remote's instructions for more information on manual code entry.
  3. Check the batteries in your remote. Weak or dead batteries can cause issues with remote functionality.
  4. Check if the remote is in the correct mode for the device you are trying to control. Some universal remotes have multiple modes for controlling different types of devices, such as TV mode, DVD mode, etc.
  5. Check if you have the right remote for your TV, if not, try to find the right remote.
If none of these troubleshooting steps work, you may need to contact the manufacturer of your TV or the manufacturer of your universal remote for further assistance.
My recommendation
https://amzn.to/3WfBNpJ
https://amzn.to/3INRZeH
How do I program my F-2100 universal TV remote
Programming an F-2100 universal TV remote can vary depending on the specific model, but in general, the process will involve the following steps:
  1. Locate the Code List: The F-2100 universal remote comes with a code list that lists the codes for different TV brands. This code list can be found in the manual that came with the remote or can be downloaded from the manufacturer's website.
  2. Turn on the TV: Make sure the TV you want to program the remote for is turned on.
  3. Press and hold the TV button: Press and hold the TV button on the F-2100 universal remote until the light at the top of the remote turns on.
  4. Enter the code: Using the number buttons on the remote, enter the code for your TV brand from the code list. For example, if your TV brand is LG, you would enter the code "10178"
  5. Test the remote: Once you have entered the code, press the power button on the remote. If the TV turns off, the remote is now programmed to control your TV. If the TV does not turn off, repeat the process, trying different codes from the code list until you find the one that works.
  6. Repeat the process for other devices: If you want to program the remote for other devices such as a cable box or a DVD player, you will need to repeat the process, using the appropriate button for the device you want to program.
It's important to consult the manual or contact the manufacturer for detailed instructions of your specific model
I need to know how to program this remote to a broksonic tv please?
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
What must i do to start programming my remote to my tv
First look up your TV code in the manual (link below). Some TVs are manufactured by another company, so you can try codes for the manufacturer's TVs as well. Funai makes a number of brands (including Emerson); your TV manual may indicate the manufacturer.
Then turn on your TV, if possible. Then press and hold Set (just below the LED) until the LED blinks twice. Enter a four-digit code with less than 10 seconds between key presses. Press the Power button and check if the tv turns off (or on). If the TV does not respond, try a different code. When the TV responds, check if the other functions of the remote work.
One For All remote manuals and code lists are available here: http://www.oneforall.com/support/manual . Use the drop down menus to select Universal Remote and then the model. You may need to change the Region at the top of the page.
The direct link to the URC-1050 manual is: http://www.oneforall.com/uploads/support/71565305a95bc645c30a7af2b6994b71.pdf .
Please note that the manual for this remote has a copywrite date of 2002. Most universal remotes are limited to codes for devices released 6 months or more before the remote was programmed. If your TV is newer than your remote, you may need a new remote.
I hope this helps.
I lost my remoe and manuel.I went to walmarts and bought a universal remote taht say its compatable with Broksonic..I will not work..want turn tv on or off? any sugestions?
U should turn on the tv ON manually by the tv power button to get the tv ON and used all the codes that was provided by the universal remote user manual for the ur tv brand Broksonic.U must follow the directions carefully and enter each codes correctly,the correct universal codes for tv is enter,ur tv will able to work by the tv universal remote power button will able to turn the tv off/on of the tv set.If none of the tv universal codes that was provided by the universal remote user manaul for ur tv brand Broksonic don't work.Just return the thing to Walmart and get ur money back.Try website like Remotes.com to buy the tv original remote,than 100% will work for ur tv set.
Orig. remote wore out. Can't get a universal remote to accept TV code. Entered the number codes in the universal kit, none will work. Any suggestions?
Hello
have you checked with these codes with it:
Three digit universal remote code for Broksonic are:-
136/ 147
Four digit universal remote code for Broksonic are:-
0147 0135 0250
0257 0310 0394
Proceedings
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
NB: Just switch On and Off the TV with its power switch on the front panel [NOT BY THE REMOTE CONTROL HANSET] before trying an other code.
ok.
Can't program the DVR remote to cut my broksonic tv on or off.
what is the code for broksonic universal remote code
2helpful
2answers
Cant get universal remote to work with broksonic tv
To purchase a replacement try this site
Have you tried these codes? 0236, 0003, 0463. If the remote only uses 3 # drop the first.
Top Broksonic Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
