I have a Mitsubishi VS-50607 Serial # 101570 and the green light turns on for three seconds I hear a click then the light goes out. Any thoughts on what might be wrong?
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
I'm having the same problem. I did the self-diagnosis and the results were 2-4 blinks. Now my question is what do i do to fix it or better yet what part i need. Thank you
I'm also having the same problem. The green light flashes, has no picture or sound, then clicks and shuts off. Same Model Mitsubishi VS 50607.
Turns on then green light goes on then turns off the tv
