SOURCE: Rotten Egg Smell
Repair man told me this is common with front load washers. I was told to put Sunlight dish washing detergent (for dishwashers not hands) in the machine (about 1/2 cup) and do a hot wash with the machine empty.
Make sure the rubber door gasket is clean. Pull it back and clean under and around it. The gasket will collect dirt and begin to mildew causing various odors. Run the machine empty, boil a medium pot of water to almost boiling, then put it in the machine during the wash cycle. This will help clean the lines, during the rinse cycle place a 1/2 cup of vinegar in the unit. Make sure you are using HE detergent. 1-2 tablespoons will due. If your using liquid fabric softner, dilute it by half. These machine use less water than a typical top loader and can't dissolve regular detergent effectively. There by causing your lines to get clogged with gunk.
SOURCE: need an egg boiler
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=3732&secid=53&linkon=category&linkid=98
SOURCE: 4-slice egg & muffin toaster
On my fourth one now...love the idea, but the egg poacher keeps burning out.
The 800 number is 1-800-688-1989
Calling them now...this last one only lasted 3 weeks.
SOURCE: Egg Smell
We fell prey to the same desire to have the state of the art, economical and supposedly gentler on your clothing front loading washing machine. Bosch WFK 2401 and I have found a solution but it is not pretty for those of you who have a washer not hidden in a laundry room.
I keep the kick plate off at the base of the front of the washer. Using a low profile pan, an 8 x 8 cake pan is about right and immediately after every wash plase the small drain hose over the pan and open it. The pan fills about half way with water that is left in the bottom of the drain system. Doing this prevents the next load from being exposed to the rotten egg water.
It must be done at the end of every load. I too keep the front door open when not in use and pull the detergent/softener draw open as well.
Good luck. Can hardly wait to justify that I have lived with this long enough to purchase a new top loader!
The average female flea
will lay her firs egg after 26 hours after her first blood meal. Fleas lay up
to 50 eggs per day the reason is because they **** blood up to 15 times their
body weight.
