Minn Kota Deckhand Electric Anchor Lifts Deck Hand 25 Logo
A
Anonymous Posted on Oct 11, 2013
Deckhand 40 will go up but not down - Minn Kota Deckhand Electric Anchor Lifts Deck Hand 25
1 Related Answer
Anonymous
  • 4961 Answers
  • Posted on Aug 25, 2012
SOURCE: minn kota repair manual for deckhand 40
Manual:
http://store.minnkotamotors.com/media/document/2377106rg.pdf
1helpful
Minn Kota DeckHand 18 won't run
Did you check the breaker and fuse. The strain of a rope foul would trip the breaker.
Page 18 shows breaker in circuit for the DH15 - DH25
https://productimageserver.com/literature/ownersManual/36957OM.pdf
Fuse or circuit protector ' Boating Forum
iBoats https://forums.iboats.com > threads > fuse-or-circuit-pr...
Mar 9, 2021 - I just purchased 2 Minn Kota DeckHand 40 anchor winches. They have built in circuit breakers, but should I also run fuses to them as well?
You would need to strip it and test the motor. You can still get parts by the look of it.
https://www.google.com/search?q=Minn+Kota+DeckHand+18
Minn Kota deckhand DH 25 lock up when up at top out of the water.
Does the nylon rope look bunched up inside the housing. My guess is bad spooling. Let all the link out and control it back in so that it is nice and even.
https://www.wholesalemarine.com/minnkota-dh-25-deckhand.html
There is a phone number in the manual for support
https://productimageserver.com/literature/ownersManual/25449OM.pdf
Please explain the difference in the deckhand 40 anchor winch and the pontoon deckhand 40 winch? is one got bigger stronger gears and heavier housing faster retrieve etc? thanks john
The 40 signifies the same power output, pick the one that's best for your individual needs regardless of the title as both have the same amount of power!
Let me know if this is helpful by clicking "Helpful", feel free to leave very brief review or follow me, I deal with automotive/mechanical/technical and other subjects relevant to daily life. Thanks and have a great day!
6helpful
3answers
Anchor will not go down but will go up
I have two deckhand anchor units. I ve tested both on battery, and both went up. I replaced switches, and I get nothing, but I heard a light click coming from unit. Is the motor bad?
I have a Minn Kota Deck Hand Ser. No. MK01798492 I can not find a modle # on it. It came on the boat i bought used. it did work now it will not let the ancor down. I took the cover off, found a spring off...
39 2372700 COIL SPRING ??
DeckHand 40, 12 Volt, 25 to 40 Pound Capacity, 2377106 - 2004,2005,2006,2007,2008,2009,2010,2011,2012,2013,2014,2015,2016,2017
DeckHand 40 - parts diagram
1helpful
Minn Kota Deckhand stripped gears
Hello!
Here is a schematic for your Deckhand:
DH40
The install of the large plastic gear is fairly easy if you are somewhat mechanically inclined (you must be if you posted the question ;)
Give it a go, last one I did took about 20 mins.
Mike
Sep 26, 2009 • Boating
Top Minn Kota Boating Experts
ADMIN Andrew
ADMIN Andrew
john h
vince
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
