Timex 5G971 Heart Rate Monitor Ring Watch Logo
Posted on Apr 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Timex heart rate monitor does not keep correct BPM. I changed the battery, now the heart rate hovers in the 30' and 40's, never getting to the correct BPM
  • Anonymous Mar 26, 2012
    Check to see that the watch is set to display the beats per minute instead of the percentage of maximum. I changed my battery and the watch reverted back to showing the heartrate as a percentage and it read in the 30's and 40's until I got going, then would never climb above the 80's. The fix was to change the way the heartrate was displayed. The monitor was just fine.
  • Anonymous Mar 22, 2014
    How do you set the date on the W/R 30M Heart rate monitor? Holding On/Off nad the attempting to adjust month and day does not work. Any thoughts?
David Shaub
Level 3:
President:
  • Master 2,994 Answers
  • Posted on Apr 23, 2009
David Shaub
Master
Level 3:
President:
Answers
2994
Questions
Helped
1153455
Points
8370
Make sure the back of the watch is spotless and your skin isn't too dry.
Heart rate display is not showing correctly - it's too high
It is easy to check your heart rate. Place your index finger on your carotid artery on your neck. count the pulse for the seconds. multiply by 6 for beats per minute. If it does not match your monitor contact customer service for repair. If it does match your monitor call your cardiologist.
http://www.raytech.ca/en/services/repair_service.asp
3helpful
Manual of Timex Zone Heart Rate Monitor watch . Model T5H881F5
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please .
The resin straps on either side of my heart
Where can I take my son's Marcel Drucker to get the crystal face that was broken in pieces?
Timex M515 Heartb Rate Monitor in correct readings
I´m experienced the same problem of incorrect readings after a long time without use. I cleaned the rubber parts of the chest strap with soap and water, than I use some silicone grease or other silicon liquid to keep the rubber hydrated. Make a careful cleaning in the contact area between the rubber and the plastic parts, the fissure in these area use to be full of "sweat dust".
1helpful
Polar F6
It sounds like most of you have the heart rate set to display in % of max heart rate. Most Polar products have the option of heart rate in BPM(beats per minute) or percentage of max.
If you look at the display during the exercise, you will see a % icon. You can turn it off in by hitting the back button and go down to HR view settings.
Hope this helps.
Chris @ Polar USA
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
