Posted on Apr 23, 2009
Boot Error Shutting Down Sony NWD-B103
I charged it for the first time, it never started again, always giving the message; "Boot Error Shutting Down". Computer doesn't open it, recognise its capacity. nor does format it. What can I do? Please Help... my mp3 has a same problem with them ..when i open my mp3 it appears a message "BOOT ERROR SHUTTING DOWN"..what will i do?my unit is NWD-B103F..help me pLease.?ASAP.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 30, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1059
Points
6
Down load teh latest firmware from following link & update your player...............cheers....!!!!!!!!!!!!!!
http://www.sony-asia.com/support/download/product/nwd-b103f/modelfirst
Sameera
Boot Error Shutting Down Sony NWD-B103F
Contact Sony Tech support via email. they should be able to help. it is free I think.
8helpful
4answers
I hav this sony walkman nwd b103 model.. it says boot error and shuts down... i fixed it using firmware1.3.. but it used to have a FM mode.. after the error there is no FM mode.. what do i hav to do to get...
I would check and make sure you got the correct firmware. 'A', 'S' and 'F' on the end of the model is important. If you use a firmware with no FM, you will have no FM.
9helpful
4answers
BOOT ERROR
it might be serious check out with the service centre ........
9helpful
4answers
Sony walkman b135 say boot error after that power
6helpful
My Sony Walkman NWD-B105 reports 'Boot error shutting down'
i have a problem when i start my mp3 it gives format error even i have formated my mp3 but it's giving me the same error please tell me its solution...
129helpful
19answers
Had a similar problem with the B103F. Not sure it will work for the non F version.
Goto Sony's support site at http://www.sony-asia.com/section/support.
Search model - NWD-B103F (non F is not listed)
Look at the "latest downloads" and select the "firmware update program". (alternately you could first select the "download" section and then select the model.)
Download.
Run (without the unit plugged) and when asked plug the unit. To be on the safe side, ask it also to format the data section.
When finished, the unit should be OK.
2answers
NO SIGNALS ON NWD-B103 SONY MP3
i think that your mp3 players battery has died of use or overcharge and you need a new one so i would take it to a retailer of your mp3 player and see if they can get a new battery for you
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
