My n500 will not boot. the power led and battery led comes on and then once in a while the hard drive led comes on with the volume controll leds. However no display. it seems as if the machine is not passing POST.
Are you sure the display is good?if it is failing POST then you have a hardware issue you should be able to access the bios prior to POST if you get nothing at all no prompt no screen flicker i'd say your issue isn't the computer failing POST it is something in the screen or the. first test your monitor if you can hook it up to a desktop monitor make sure the lid is closed.
if its not the monitor try pulling the battery while not plugged in.make sure it isn't stuck in hybernation.can you open a panle in the back to clear the cmos?are ther any beeps?only other thing i can think of since it is a laptop is the memory.if you can try a boot disk like "the ultimate boot disk"and test the memory.
http://www.ultimatebootcd.com/
hope i was of some help
Ok it seems you should check its ram module. Reseat it or clean at the most with soft eraser its edge connector. But you should first disconnect its battery and other power source, and shut down completely before performing a cleaning on ram module.
regards
