SOURCE: Olympus Stylus 410 Digital is taking grey/black pictures
The problem you are describing is a problem with one of the chips in the camera that controls image processing. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $83 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
SOURCE: flash Does not work. Can only take pictures in flash-off mode
The problem you are describing is a problem with the flash charging indicator switch inside the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
SOURCE: Telescoping lens opens but the view finder
Before trying the new battery, try cleaning the battery compartment contacts with a cotton swab dampened, not drenched, in rubbing alcohol. Blow dry the compartment and then try the new battery. Thanks, Dana
SOURCE: olympus stylus 7030 flash problem
It could be circuit, capacitor or the flash tube itself? Digital cameras are so cheap now that buy a new one is a good choice.
dear sir,
the problem lies with your memory card ahich is being infected by virus or corrupted.......
if your card is working fine in other cameras then this is the problem usually caused by viruswhich happens when you are receiving files from p.c or untrusted mobiles...... and sometimes it might be software failure also, which causes some of the menu not tofunction,the only solution is to flash ur phone software from the nearest olympus care.
thank you..take care
