Spectra Holder - rod. . Front Door Mechanisms; REAR DOOR LOCKING; Logo
Anonymous Posted on Oct 11, 2013
Kia door panel - Spectra Holder - rod. . Front Door Mechanisms; REAR DOOR LOCKING;
Passenger door on drivers side won't lock anymore.
door lock actuator seized inside the door or broken wire in the door does it lock and unlock by hand or key sometimes the rod breaks inside the panel to findout remove inside door panel and check
@att.netmy window will not go up on driverer side could it be a fuse
Had similar problem with my 2004 Kia Optima. I could control the driver window and door locks with the panel but the other windows and door locks would only work one way (open or close but not both). Had the switch panel on the driver's door replaced. Windows all worked after that but still had issue with door locks ... I can lock them all, just can't unlock them from the driver's door. They have to be unlocked from each individual door. I guess can live with it. FYI ... the switch panel for the driver's door was $250 from a Kia dealer so you might want to check salvage yards for it.
Re-install front door panel's on a 2000 Kia Sephia
pls. be more specific in describing the problem/ door panel means the complete door/ u mean u took off the whole door to install speakers? or just the door trimboard?
7helpful
15helpful
Kia sedona outside door handle replacement
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Pull back the weather seal and you'll be able to get to remove the bolts securing the outer handle on
4helpful
Remove door panel
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. If needed, you can pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything inside the door
3helpful
Replacing driver's side mirror on Kia Sorento
These instructions are for a 2013 Kia Sorento (Passenger Side Mirror)
1) remove speaker cover on inside door panel:
2) Use a small screwdriver to pry it away from the door. Be careful of the paint:
3) The panel will expose the 3 main bolts that need to be removed:
4) The cable harness needs to be removed this is located behind the door panel. Remove the one screw behind the screw cover:
Once the one screw is removed it will allow you to move the door panel enough to get to the harness and the 2 bottom bolts.
Here is how the harness looks:
Once the harness is removed and the 3 bolts removed the mirror will come out.
Repeat the steps to re install your new mirror.
Top Kia Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Kardoc
 Mikey
Mikey
Are you a Kia Vehicle Part and Accessory Expert? Answer questions, earn points and help others
