I turn on the tv Vizio Gallevia and it has a blue screen and no signal
Just try to reset so picture will back to normal again, some LCD TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the LCD TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the LCD TV power button for five seconds.
4. Plug the LCD TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the LCD TV is responding again.
6. Turn off the LCD TV and reconnect the devices.
7. Turn on the LCD TV.
Hope it may help you;
Regards;
VOTIT
SOURCE: Vizio 46" Gallevia Flat Screen
any display in the corners of channel number av etc ?? if you turn the volume up and down does that show on the display if not likely to be a dead panel
SOURCE: When I turn on my
Have you got anything connected to the TV? If so, make sure they are powered on, and all connected correctly.
Hope this helps
TV_Doctor
I tried your solution and it did not work. What else can I do?
Blue screen on had I
