Question about Coby kyros Tablets & eReaders
My tablet wont charge - kyros Coby Tablets & eReaders
  • kathleen bailey
    kathleen bailey Oct 12, 2013
    m tablet wont charge when I plug it in. I have used the same charger on another tablet and it starts to charge right away. i tried connecting it to my pc with the usb n nothing!
If the cable has a micro USB connector (most android tablets do), then the connector is likely the problem. With the cable plugged in, there should be a light to indicate charging. It would usually be orange until charged, when it turns green. If you don't see the light atall, the connection is bad. Try wiggling it to see if that helps. If it does, then you will need to make sure the phone is charging somewhere so that it is not subject to being moved at all, which might cause the connection to become loose. The phone will charge faster if it is off.
Feb 03, 2015 | Mach Speed Trio Stealth G2 9.7 inch Tablet...
My meep tablet wont charge
try with a new charger,& cable or check charging connector in tab may be faulty
Jan 23, 2015 | Oregon Scientific MEEP Kids Tablet
Trio tablet wont turn on
sounds like the hard drive is froze up
Mar 08, 2014 | Mach Speed Speed Tablet Trio Stealth G2 7"...
Tablet wont charge
The charger socket has probably broken its solder connections, happens because of repeated movements straining it by using it when the charger is plugged in. Have you tried charging it through the mini usb socket?
Jun 05, 2013 | Samsung Tablets & eReaders
Tablet wont turn on
Try to charge it by the original adapter as the PC USB output is not power full enough to supply charging for it
Apr 29, 2013 | Sanei N78 7 Inch Android 4.0 Tablet PC...
Binatone kidzstar tablet wont charge
my daughter kidzstart Ereadrer wont turn on or charge ive got the usb connected and its still not doing anything . can you help ?
Jan 07, 2013 | Tablets & eReaders
Le pan tablet wont charge how to reset
so my tablet wont charge but it turns on but the battery stops then turns off.so what should i do about it.
Apr 28, 2012 | Tablets & eReaders
Tablets & eReaders Logo
Top Coby Tablets & eReaders Experts
Harrie
Kolbrun...
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
