Peavey Electronics Peavey PV10 Mixer Logo
R
Rick Morris Posted on Oct 10, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to know how to connect a powered subwoofer to the peavey 10 mixer
  • Rick Morris
    Rick Morris Dec 20, 2013
    All hooked up and work's fine. Thank's everybody for the help.
Power Electronics
Level 2:
Champion:
  • Expert 243 Answers
  • Posted on Nov 07, 2013
Power Electronics
Expert
Level 2:
Champion:
Answers
243
Questions
Helped
61577
Points
270
Connection is hooking up from mixer's main outputs (L,R) to
Subwoofer amp inputs.
  • Rick Morris
    Sorry i have'nt got back to. Your solution worked. Thank's
4 Related Answers
Anonymous
  • 17 Answers
  • Posted on Mar 09, 2011
SOURCE: i have the peavey xr
That's easily done. Simply connect the left(or right) output of your mixer to one of the channels on the peavey. Use any line input. Since the peavey is a mono system, there's no need sending a stereo mix to it.
Anonymous
  • 4234 Answers
  • Posted on Dec 10, 2010
SOURCE: can i connect the pv 112 to the pv 118 subwoofer
Generally speaking you should only send low frequencies to subs. The highs, while lower in power than the lows, will over time harm the voice coils. The ideal way to do this is to use an external crossover netween the main output and the amp input with the higher range going to a general set of speakers. Send the lows through the second channel of the amp and then to the subs.
In short, while not recommended, yes you can hook them up in parallel.
Dan
Fred Yearian
  • 5603 Answers
  • Posted on May 16, 2011
SOURCE: My Peavey PV-118 18" subwoofer
Peavey uses a protection network and sometimes it gets blown when too much power is sent to the speaker. The speaker may be blown however. Peak power for this is 800 Watts and 400 Program... That is NOT RMS power. Make sure your amp is no bigger than 300 Watts RMS driving this. If you are REAL lucky, maybe a lead has fallen off the speaker... Open the unit inspect and test the components.
Fred Yearian
  • 5603 Answers
  • Posted on Sep 22, 2011
SOURCE: How do i hook a
You CAN drive the power amps from the main amp inout jacks BUT the rest of the inout of the 8600 would be dead then. You can connect the L and R from the FX24 to either the media RCA jacks or into the channel9/10 jacks. FOr the latter, use TRS cables. Leave the two selection buttons in the up position.
1helpful
2answers
How do I connect my Bose l1 compact to Peavey xr 8600?
You would come out of the Main output on the front of the mixer into the line in on the Bose.
You may find this site useful- L1 Unofficial Performers Guide
I want to record using Tascam with my peavey xr1220 mixer
What Tascam recorder are you using? If you are multitracking you will be unlikely to be able to use this mixer. Otherwise get a phono lead to fit the tape out and suitable connections for the Tascam recorder at the other end. This will allow you to record the main mix but unless you are a solo act or putting everything through the PA this will probably be pretty useless to you.
2helpful
How do i hook a peavey fx24 mixer to a Peavey xr8600 with out going through the 8600's mixer? I am wanting to use the 8600 to power my mains and use another amp to power my monitors. can i do this?
Connect Qsc pair kw122 powered speakers and kw 181 powered sub to peavy pv14 mixer?
Two things... Use BALANCED LINES, either XLR or TRS... AND power the mixer from the same receptacle or power conditioner as the speakers and the sub.
2helpful
I have the peavey xr 8600 and i wanna know how to connect an additional non powerd mixer to it ( i wanna use the peavey as an amp??
Can i connect the pv 112 to the pv 118 subwoofer since the powered mixer i bought it only has 2 main outputs? The powered mixer I bought is the PV XR 8600D powered mixer...
Dan
Hi. I have a Peavey xr800f. Where can I connect a 400 W active subwoofer?
If the subwooofer has only a single input, then connect it to the Monitor output which does a mix, HOWEVER the level will NOT vary with the main sliders, but only with the monitor pots... This is NOT really practical for performances.
There is no mixer built in the unit, so you might make a simple resistive mixer taking the "Master out" left and right using 1K ohm resistor from each to a common point that feeds the subwoofer. Tie the grounds of the sub and mixer together.
FOR SYSTEM SAFETY always power the mixer and active speakers or any interconnnected equipment from the same receptacle or source.
Aug 21, 2010 • Music
Top Peavey Music Experts
NOEL
NOEL
Ngoro
Are you a Peavey Music Expert? Answer questions, earn points and help others
