The digital screen come up with F21. How do I fix this
F21 means the washing machine has a “water draining issue”, meaning the drain pump itself, or the drain hose is clogged and the washer is having problems draining the water out. In other words, the washer is taking too long to drain the water out of the tub. If you have a front load washer then you need to locate the drain pump which is usually located on the bottom front of the machine. If you have a top load washer then you need to make sure the drain hose is not clogged or pinched. The drain hose is located in the back bottom of the washer
