If you have no power (12v) to the power wire at the A/C compressor clutch and have jumpered all of the switches then you need to check for power coming out of the A/C switch on the dash. Also there might be a pressure switch on the back of the compressor that you can jumper also. You can also check A/C compressor relay in the under hood fuse/relay box. There might be a fuse in the under hood fuse/relay box for the A/C too. Hope this helps.
