Question about ESQ Watches
Movado serial number lookup
Esq classica
SOURCE:
  • 61 Answers
SOURCE: I just need to remove 2 links and I do not want to
Take this to a jeweler or pound out the pins with a paperclip width rod of steel or pin pusher and a hammer.
Posted on Oct 17, 2009
gemineye61
  • 841 Answers
SOURCE: I have a movado watch the serial number is 84 e7
As with luxury bags, luxury watch brands such as Movado are copied and sold illegally. Movado watches are popular among both men and women, but sellers of replica watches hurt the brand by providing the buyer with poor craftsmanship. Dealers know what genuine Movado watches look like, and they are familiar with the watch model names and numbering system. While you can take your watch to a dealer to closely inspect its authenticity, you, too, can learn how to tell if your Movado watch is fake by noting a few details.
Check the material the watch is made of. Replica watches are made of aluminum, and they don't have the same heavy weight of an authentic Movado. Movado watches should feel like quality, solid pieces. True Movado watches are made of stainless steel.Observe the movement of the watch. The movement of the second hand should not be erratic or shaky. It should look smooth as it travels across the face of the watch.
Look closely for scratches on the glass face. Movado watches are scratch resistant, so any imperfection on the face is a telling sign that it's fake. Hold the face to the light and observe if it gleams like a genuine watch. If it's dull or cloudy, it's not authentic. Also, look for the inscription "Swiss Movado Made" to make sure it's authentic.
Feel the links and the clasp on the watch. Clasps should feel solid, and the links should be joined together by screws. Gently pull on the clasps and check for any loose pins. If the clasps feel fragile, it's probably fake.
Posted on Jul 26, 2010
rockmeister
  • 2047 Answers
SOURCE: I need a valuation on
Hello there, the serial number on a Movado watch is usually unique to each watch and therefore a watch cannot be identified by that. Here is a picture of all the gold ladies Movado watches which are presently available. I have numbered them 1 - 8 accordingly.
1 and 2 are both tagged the Amorosa and are valued at $895 and $1395 respectively.
3 and 4 are both tagged the Concerto and are valued at $2495 and $1495 respectively.
5 and 6 are both tagged the Bellamoda and are valued at $1495 and $1095 respectively.
7 is the Harmony and is valued at $895
8 is the Rondiro and is valued at $1495
If your watch is not on the list above then you might want to send it to the nearest Movado authorised dealer to confirm if it is original or a knock off.
Hope this support has been helpful?
Thank you for visiting FixYa
Posted on Sep 11, 2011
  • 3 Answers
SOURCE: Nowhere in the little operations manual that came with my watch does it give the accuracy of the timepiece. Where can I get that information? I have a movado ESQ bracer chronograph.
Interesting question. I know little about watches but, as you would know, your watch does have a quartz movement, so, from Wikipedia, 'Quartz clock':
Standard-quality resonators of this type are warranted to have a long-term accuracy of about 6 parts per million at 31 degrees C (87.8 F): that is, a typical quartz wristwatch will gain or lose 15 seconds per 30 days (within a normal temperature range of 5 deg C / 41 F to 35 deg C / 95 F) or less than a half second clock drift per day when worn near the body.
If a quartz wristwatch is "rated" by measuring its timekeeping characteristics against an atomic clock's time broadcast, to determine how much time the watch gains or loses per day, and adjustments are made to the circuitry to "regulate" the timekeeping, then the corrected time will easily be accurate within 10 seconds per year. This is more than adequate to perform celestial navigation.
Assuming that you have a computer with internet-synced time and good internet, meaning around 1/100 second accuracy, why not compare the watch to the computer over the space of a week?
Posted on Sep 04, 2012
Sep 04, 2012 | Movado ESQ by Movado BRACER stainless...
I need a valuation on a ladies gold movado watch. Serial number A63165
Sep 10, 2011 | Watches
Hello where l can find the rubber straps(bracelt) for ESQ BLACKFIN 300m
Thank you for contacting FixYa.
The best place you can contact for replacement would be Movado itself by following the following link:
http://service.movadogroup.com/care.cfm
or you can also try:
http://www.watchbands.com/category.aspx,,categoryID,,754
Best regards. Jewel
Aug 31, 2010 | ESQ Blackfin 300m Dive Watch Black Dial...
I need more links for my watch
ESQ is Movado.
http://a3.geoserve.com/scripts/esrimap.dll?Name=L&Com=fo&Db=DLRMovall&Ds=Movado&Filt=User7%20LIKE%20%27_S%25%27
This link will provide you with an Authorized Service Center.
Jan 13, 2010 | Lucien Piccard 26024 Wrist Watch
I changed the battery in my esq swiss watch and can't get the back on the watch. What is the trick to re-installing the back
ooh, ESQ by Movado. These case backs are often pressure fit, just like Movado, and are notoriously difficult to reinstall. It sounds like it is going to take a watch press to install your caseback. This is an expensive tool which any jeweler that changes batteries will have. There is no real safe way to this without a press.
Now, I have just supposed that this is a pop off; if it is a screw on back then it would have had to have been unscrewed to get it off. If it is a screw-back then you will likely need to get a caseback wrench to tighten it down enough.
Oct 18, 2009 | ESQ Swiss Muse 07101116 Watch
New band
You can either contact Movado directly (they make the esq watches) or you can ask any REAL jewelry store to contact the company for you and ask about this as long as they carry either Movado or Esq in their store (don't ask the jewelry counter at your local department store).
Dec 30, 2008 | ESQ Swiss Muse 07101116 Watch
Watches Logo
1,450 people viewed this question
Top ESQ Watches Experts
Janelle Schoonover
Janelle Schoonover
Norman Worley
Are you an ESQ Watch Expert? Answer questions, earn points and help others
