LTD Watch Bowflex Strapless Heart Rate Monitor watch Logo
A
Anonymous Posted on Oct 09, 2013
I need to know how to set the time on my bowflex heartrate monitor watch
41helpful
Instructions for Bowflex WR30M?
In time mode, hold set (bottom right button) to change date and time. The selected (flashing) item can be changed in one direction only using the up (top right) button. Press set again to cycle through each item until desired settings are chosen.
In stop watch mode, the up button starts and stops the stopwatch, the set button will take a split time while the time is running. To reset the stopwatch, press set once while the time is stopped.
In alarm mode, the up button turns the alarm on and off. There are three alarms available. To cycle though alarm times, press set. To set an alarm, press and hold set until the time flashes, then set the alarm time using the up button, cycle through hour and minutes using the set button. When finished, press set again.
Timer mode. To set the timer time, press and hold set until the time flashes. The timer goes up to 23h:59m:00s. You cannot set seconds. Once set, the timer can be started and stopped using the up button. There is no reset for the timer, to start a new timer the time must be manual changed again.
To check heart rate, press and hold mode until PUL is shown, place two fingers, one each on the top and bottom metal contacts for 6-10 seconds to get reading (This works best when not in motion).
Apr 13, 2012 • Watches
5helpful
2answers
How do i get a polar f7 watch band replaced the watch is just over 2 years old
You can get replacement band on amazon, click here and take a look Amazon com polar band replacement. I hope this was helpful, have a nice day
4helpful
I own a bowflex precisionxt heart rate monitor and I cannot find the manual. Where can I obtain one?
Try this:
search-manual-online.com/bowflex-precision-xt-heart-rate...
Aug 29, 2011 • Watches
How do you turn the heartrate monitor on?
How do I turn the Heart Rate function on and off on my watch? Within the Date and Time screen, if the heart icon is showing, the heart rate function is on. To turn off the heart rate function, simply hold the Reset button until the heart icon goes away.
1helpful
My polar F6 watch is not reading correctly. When
This happened to me, I think it happens when theres not enough contact with skin and monitor, I put more water onto my skin and the heart rate monitor and it sorted th eproblem
3helpful
Viewing Time in Exercise Mode
Bring the watch up close to the chest-strap heartrate monitor, and it will automatically display the time. This only works while in exercise mode.
kb
2answers
To adjust time on a watch
If your watch has a crown that pulls out to set it pull crown out half a click. Then turn crown to set watch to proper dte.
Mar 01, 2008 • Watches
Top LTD Watch Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a LTD Watch Watch Expert? Answer questions, earn points and help others
