Hi
Is it a clunk clunk clunk noise? Then you have a CV joint that needs to be replaced. This is called the CONSTANT VELOCITY JOINT, and helps you turn the wheel when it is in motion.
It has ball bearings inside and when the housing wears out, they make that clunking noise.
See your mechanic for a change and see if you can replace both wheels at the same time.
Hope that helps.
Happy motoring.
G
