SOURCE: Full screen view
in order to get the full HD experience you should be using HDMI cables. if you're using the white/red/yellow cables then your HD channels will not broadcast in full HD and you'll be stuck with the annoying black things around your screen
SOURCE: Plasma TV moving black and white lines
This is a result of poor conversion of a SD signal on a HD channel. Go into your settings and adjust the h/v settings to move the line off the screen. You can do this with a combination of v-position or vsize.
SOURCE: CUSTOMER WITH A BRAND NEW VIZIO VA 320M KEEPS SHOWING SIDEBARS
The signal board is bad. Replace this board, its the one with the rca jacks and rf connectors. Warranty work will cover this repair. As we say in Nebraska.......Getter Done!!!!!
SOURCE: How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
SOURCE: Vizio flat screen tv screen goes all green (no
if you have comcast you can use your remote to change the tV program from cabke to DVD then change it back to cable. your image should come back.
I forgot to note that I am connected from an HD DVR from TWC and using HDMI
