SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
SOURCE: What is the length of the primary mower belt for a
Many of the parts you can just drop the prefix and use the Sears /AYP #
So, look at the hood sticker or in your manual for the Husq#. 532 18 08-08 becomes 180808 which is a common Sears belt for their secondary belt on the newer 48.
OEP shows as a 5/8 X 89"
The primary for these 174368 (Engine to deck)OEP shows 5/8 X 90.
Best to get the oem if you can. Never tried aftermarket on these.
Also found THIS USEFUL INFORMATION.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
SOURCE: I have a Husqvarna 5521CHV lawn mower. it stars
I don't have a solution but have the same problem. When choke opens the engine shuts down.
