Cameras Logo
a
ana pennington Posted on Oct 10, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The flash of my canon powershot sd1300 IS doesn't work. please help me!
Quinton
Level 2:
Champion:
  • Canon Expert 319 Answers
  • Posted on Oct 16, 2013
Quinton
Canon Expert
Level 2:
Champion:
Answers
319
Questions
6
Helped
40058
Points
404
5 Related Answers
fotomohamed
mohamed salim shaikh
  • 321 Answers
  • Posted on Jun 20, 2009
SOURCE: Canon PowerShot SD200 Flash doesnt work
change the flash bulb
Anonymous
  • 11967 Answers
  • Posted on Jun 10, 2010
SOURCE: i have a lens error on my canon powershot sd1300
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Anonymous
  • 68 Answers
  • Posted on Feb 17, 2011
SOURCE: the flash of my canon powershot is not working
Contact Canon
Anonymous
  • 356 Answers
  • Posted on Apr 05, 2011
SOURCE: my canon powershot SD1300 IS
They just mean turn the camera off and back on. Usually when this happens it may need to be sent out to be repaired. If you just purchased it see if it is still within the return period.
If not, you can set up a repair order with the manufacturer here:
http://www.usa.canon.com/cusa/online_repair_tracking/consumer/digital_cameras/powershot_sd_series/powershot_sd1300_is?pageKeyCode=requestRepair
Please leave feedback if this was helpful. Thanks!
t00nz
CameraR
  • 4738 Answers
  • Posted on Sep 26, 2011
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
I just recharged the battery on my Powershot SD1300 IS and now it will not turn on. any ideas would be appreciated.
Do you have another battery or set of batteries? The battery itself/batteries could be dead beyond repair. I always carry two sets of batteries. My Canon cam takes 4 AA.
tip
Canon PowerShot SD1300 IS
Good day,<br /><br />It sometimes happen that you lose your cameras user manual.<br />This can be very frustrating as you need to look up something, but you can't seem to find a manual anywhere!<br /><br />Well if you follow <a href="http://www.usa.canon.com/cusa/consumer/products/cameras/digital_cameras/powershot_sd1300_is#BrochuresAndManuals">THIS </a>link you can download your cameras user manual on your computer and thus keep a digital copy handy for all the times you need it.<br /><br />Please let me know if this information was helpful!<br /><br />Kind Regards
1helpful
Canon powershot SD1300 IS won't turn on, even with fully charged battery
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
1helpful
2answers
The flash on my canon powershot sd1300 stopped working. Even turned back to factory settings. Any ideas?
hello jglassma!
like rodel de guzman wrote, if you can't turn it on manually, then it has propably hardware failure. but try also in a dark room and also check battery is full.
regards
guru68
1helpful
When I take a video the sound doesn't work.
i dont think this will help but i have a kodak digital camera and when i do video i get no sound when i play it back. if you plug it into computer to download pics and video there will be sound with the video. thats how mine works anyway.. good luck..
Trying to connect a canon powershot SD1300 is to my Dell desktop and the computer is not recognizing that the camera is connected and powered on.
Having gone three months without a response to my query, I assume my suggestion to use a card reader solved the problem.
2helpful
How do I delete a protected image on my ixus 105 camera
Go to Canon PowerShot SD1300 IS: Playback Mode Menu
And there you have : Protect
Unselect your pfoto!
6helpful
My canon powershot SD1300 IS says lens error and to restart the camera, however i'm unsure on how to restart the camera. Please help! :)
4helpful
I have Canon powershot SD1300IS, IXUS 105, digital camera When I try to turn it on, it says: "lens erroe will shut down automatically restart canera" Please help me fix it! I'm going abroad...
So when its stuck you just push on the lens.
i know it sounds crazy, and it'll sound like you cracked it, but it really does unjam your camera!
try it!
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
