Most motors of that type have a capacitor that puts the stator out of phase with the rotor. They are capacitor start induction run motors. These also have a centrifugal switch inside near the end ot the shaft to put power to the start winding for a split second to determine the direction of turn and to increase horsepower until it is up to speed. So if it fails to start either the centrifugal switch needs cleaning (or replacement if damaged) or the capacitor needs replacing to give it its original power, or the start winding has failed from overheating. There may be a thermal cutout on the start winding that may need to be replaced if it did overheat. If the start winding burned then the motor would require rewinding or replacement.
SOURCE: hobart 60 quart mixer
the motor protection board is doing its job.you should only use 1st speed to mix pizza dough.im a hobart technician and service these mixers all the time.let me know
SOURCE: Hobart 20 quart mixer
Hi im a service tech for hobart.I cant give service manuals out because i could lose my job but i can step you thru your problem with the mixer,let me know.
SOURCE: I need the manual for the Hobart 20 Quart Mixer
Hobart doesn't release their service manuals to the general public,however i'm a hobart tech and repair these mixer's often.If you need any help let me know.
