SOURCE: heater in 2001 jaguar s type not blowing hot air
check for hot water, check for power to blower, do a little work yourself before asking questions, if you can't do this then you really need help
SOURCE: my 2001 toyota tundra heater wont blow hot air. I
If you've changed the coolant recently, it could be air locked in the heater core. To remove park the truck with the front higher than the back and remove the radiator cap. Start the engine and let it run while watching for a big air bubble burp coming out the radiator neck. Top off the coolant and continue.
SOURCE: '98 S-10 heater blowing cold air - not hot air
will the air flow switch from floor to the mid to defrost? if so then we have a problem with the tempature door actuator. easy to replace just in tight place. Keep me posted for more help or if this was any help thanks
SOURCE: Heater doesn't blow hot air
First check the coolant level in the radiator. Check your heater core hoses on the firewall underneath the hood. Let the car come up to temp. and feel the two hoses. If only one of them is getting hot you may have bad heater core or a bad heater control valve.
SOURCE: Why doesn't the heater blow hot air?
If your "Check Engine" or "Service Engine Soon" light is on, you need to have that checked out first.
If not, the next thing you should check is your engine coolant level. (Antifreeze) If the coolant level is low, the engine coolant does not circulate through the heater core and the the heater doesn't work. The coolant level could be low for a number of reasons including a leaky hose, water pump, or head gasket. In any case, if it is found to be low, you need to find out why.
If the coolant level is OK then the thermostat function needs to be checked to make sure that the engine is reaching operating temperature.
If all of the above checks out OK, then the heater control valve and/or the blend air door in the HVAC housing needs to be checked for proper operation. (NOTE: some cars are not equipped with a heater control valve)
