I have to ask--is it installed/mounted correctly? You can try to power cycle the TV to see if that corrects the issue. To do so, turn off the TV and unplug it for about a minute. Then plug it back in & turn it on. If you made any changes to the settings, restore them back to factory defaults.
power off the tablet
then press power and volome down simultaneously
until you see the reset menu select reset with up down keys
acknowledge with power to reset
I have to ask--is it installed correctly? Try to power cycle the TV by unplugging any components that are connected to it, unplug the TV from the wall for a few minutes and then plug it back in & turn it on. Restore any settings back to factory defaults. If the issue still persists, then I would recommend calling to schedule repairs.
U.S., Canada, & Puerto Rico - 1-800-305-2204 Mexico - 1-888-882-7326 daily from 7 am - 12 am CT.
Hello
To enable close cationing on your TV follow this:-
[1] Press "Menu" button on the remote control to appear "Setup" menu on the screen.
[2] Use "Up and Down" arrows on the remote contol to select "Captions/Text" on your screen.
[3] Press "Right or Left " arrows to select any one of the following options. Caption-1, Caption-2, Caption-3, Caption-4 Text-1, Text-2, Text-3, Text-4.
[4] Press enter to return TV viewing.
To turn the caption feature to "On" or "Off'
[1] Press menu key on the remote control to display "Setup" menu.
[2] Using "UP/DOWN" buttons to select captions on your screen.
[3] Press "Right or Left" arrow to switch the captions feature 'ON" or "OFF" or "EZ Mute"
[4] Press enter to continue.
Ok.
Use the remote to go into the menu and change the screen position. There are 4 to choose from, flip left, flip right, flip upside down left, flip upside down right. It may be tricky to navigae the menu backward though.
in your menu there is a couple of options, one for use with mirror that flips the picture, another that flips the pic for mounting upside down. and another for flipping it upside down with mirror.
please select normal in this option as your prob just mounting it on a desk or table.
good luck
look for a small pinhole somewhere on the camera body. then insert a pin to reset the camera. if no pinhole, remove batteries for a long time (about 24 hours) then try again.
