Water is left in the bottom of the dishwasher after completing a cycle
When you find water left in the bottom of the dishwasher... most of the times there is an "Intake/Drain" flashing, or some other type of fault indication. The dishwasher has faulted out, in the middle of a selected program. The dishwasher won't even bother to drain the water out. If it's not a drain fault, then you can drain the water out by: switching the dishwasher off and on again; selecting a program; and closing the door. Open the door after 15 seconds and see if the water has drained out. If it didn't drain, there is a drain problem. If it did drain, then it can be several things. To better determine the problem, you will have to pay close attention to when the dishwasher faults out.
