Kohler Toilet Seat - Elongated Front Quiet Close Quick Release - Cachet by Logo
A
Anonymous Posted on Oct 08, 2013
Adjust laura Ashley soft closing toilet seat
5 Related Answers
Anonymous
  • 33 Answers
  • Posted on Feb 03, 2009
SOURCE: Quiet-Close Kohler toilet seat lost its quiet close feature
Hello len_moon, Look under plumbing in your yellow pages for a Kohler distributor. Also here is the web page for you part numbers. You will need the hinge assembly. Copy and Paste to your address bar. Hope it helps!
http://www.kohlerserviceparts.kohler.com/ServicePartsPage.aspx?DocumentID=c83b1f213d0545f984b01b9f0be37b9d&ModelID=558da26604ce43ec98c83fe8ed0aa604
David Shaub
  • 2994 Answers
  • Posted on Feb 18, 2009
SOURCE: slow closing toilet seat not working
It needs a new air shock on it. You might be able to take the old one apart and fix it but replacement would be best.
Anonymous
  • 81 Answers
  • Posted on Jun 02, 2010
SOURCE: QUIET CLOSE TOILET SEAT COVER
There is no adjustment for a slow close/quiet close seat. It would defest the manufacturers intent.
Anonymous
  • 70 Answers
  • Posted on Oct 30, 2010
SOURCE: My Kohler slow close elongated toilet seat is
this type can not be adjusted.
BarrettDenCo
Barrett Palumbo
  • 1772 Answers
  • Posted on Dec 29, 2010
SOURCE: Quiet close toilet seat no longer closes slow on
Sorry to read about your problem, I hope this helps you out.
Contact Kohler, and they will take care of you.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1helpful
How do I remove toilet seat?Appears to be 2 bolts with top access only.
rak soft close toilet seat - YouTube
? 0:31
https://www.youtube.com/watch?v=RLssM9BYJjg
Oct 9, 2013 - Uploaded by Paul Hooker
rak soft close toilet seat. ... How to remove and change a Villeroy & Boch toilet seat with top fixings ...
Rak Series 600 Back To Wall Toilet - YouTube
Nov 29, 2015 • Home
2answers
How do i fix a soft closing toilet seat
some of these have bolts under seat...you turn seat to left or right by grabbing while in closed position...this will release the seat from the holding bolts...then tighten the bolts....then reset the seat on bolts then lock down by doing the opposite as you took off...
Oct 10, 2014 • Home
Why does my kohler quiet seat not soft close anymore
The cams are worn out inside of seat or it may be to lose you have to tighten up the seat if there is any adjustments if not it is worn out replace toilet seat.
2answers
Soft close toilet seat
Mine is a Bemis and does the same thing. Seat drops and lids does a slow close! Are you going to takes yours back for a new one?
Jan 18, 2014 • Home
1helpful
2answers
The toilet see is not tight. How can I tighten the seat? I have an elongated seat with the soft closing lid.
Right behind the bowl on the underside there is a nut on either side that holds the seat on...tighten those nuts and it will tighten down the seat...
heatman101
I have a Jika Mio soft close seat with a loose hinge which I cannot reach due to closeness of pan to wall!!
The top lid of my soft close toilet seat slams shut.How do I adjust Jiko Mio close coupled toilet.
37helpful
2answers
Can you help re fitting cedo rue toilet seat
Had same problem, this website has the instructions:
http://www.haro-sanitary.com/technical_intelligence_ENG_HTML.htm
Dec 08, 2009 • Home
Top Kohler Home Experts
john h
ZJ Limited
ZJ Limited
Are you a Kohler Home Expert? Answer questions, earn points and help others
