Husqvarna 125B Blower Logo
Steve Wright Posted on Oct 09, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to know the starting point and how may turns to adjust the high/low speed carb screws. I have the tool. but no in fo.
Dave
Level 2:
New Friend:
  • Expert 101 Answers
  • Posted on Oct 16, 2013
Dave
Expert
Level 2:
New Friend:
Answers
101
Questions
0
Helped
46399
Points
147
Both screws start at 1 turn out....Adjust High speed till it 4strokes and 2 strokes usually 1/8 turn either way....then adjust idle so it revs staight up...should be same 1/8 turn either way from start...if it is more carby will need overhauling..
Poulan1500 starts but dies when opening choke it runs with trigger all the way in after warm uo it dies when opening choke just a little
May be plugged carb but often this is high speed and low speed carb adjustment. Requires special tool to fit adjustment screw...i always take the carb off and use dremel to cut these two air mixture screws....cut a slot on the top turning them into a slotted screw, then open each one counterclockwise 1/4 turn when carb is reinstalled. Run it and make adjustments two low and high speed screws till it idles nice and throttles up smooth and quick.
Apr 16, 2019 • Garden
How to adjust high and low speed carb screws on Husqvarna 122C
You will need a special tool to adjust the anti tamper screws, do not adjust them to over come some underlying problem i.e dirty fuel, blocked air filter or dirty or blocked air filter. if the screws have not been touched this will be a good starting point, both screws are fuel screws so unscrewing will increase and richen the mixture,
Always start with the L screw first, with the engine running gently screw the adjuster in leaning the mixture, the engine rpm will start to increase, at the point where the engine then starts to die unscrew the adjuster about 10 minutes on a clock face, the H screw will control the high rpm, with the trimmer cord pulled out to the correct length open the throttle fully, screw the adjuster slowly in or out to achieve the greatest maximum speed too far in it will die, too far out it will die, allow the engine to idle, snap the throttle open it should pick up without hesitation, if not turn the L screw our slightly to increase the fuel supply.
Bought new carb for ryobi blower need to set up carby so it will start
Set both the high and low mixture settings two full turns back from the closed setting(full clockwise).. Set idle speed for all ahead full.
Start sucker and after a warmup throttle it down and then start adjusting the low mixture screw for fastest idle. Then lower idle some more but not to point where it starts to run rough. Then rev the sucker to high speed and adjust the high mixture for max speed. You may have to make a slight adjustment on the high speed to get a smooth transition from low speed to high.
2answers
What kind of tool do you use to adjust the carb? where can I buy one?
Hi Mr. Martin:
Not quite sure what kind of adjustments you want to do.
All the chain saws that I've experience with have two slotted screws, one high speed, and one low speed. There may also be an idle stop adjustment screw.
Adjustments typically consist of:
1) with the saw running, adjust the low speed screw so that the engine is running smoothly.
2) with the engine running, increase throttle to maximum rpm and then adjust high speed by leaning (screw in) until maximum rpm starts to drop off, then back out 1/3 turn.
3) let the saw return to idle rpm. should be smooth, and chain not turning. Adjust as necessary.
Tool required is small screw driver. It can help if you put a small piece of plastic hose over the blade so that it will not slip off the head of the screws.
Cheerfuls
Nov 16, 2015 • Garden
HOW DO YOU ADJUST CARB ON STHIL CHAIN SAW
start by turning adjustment screws in. turn low speed out one turn and the high side 3/4 turn. start engine and adjust accordingly. the one turn and 3/4 turn are the starting point. saw should start at these settings and then you can fine tune. without knowing your elevation I can't give you the number of turns .
Oct 13, 2014 • Garden
Adjustments carb zama
1.5 out each usually... Try it around there I guess
1helpful
How do you adjust the high speed mixture screw? I have a Ryobi RLH1100a MK III 31cc line trimmer, and after changing the fuel lines, it will start but not idle more than about 3 - 5 seconds before it...
Hi montex124, I will try to help. In the past few years carb makers have been making changes. Some carbs have no adjustment at all, the ports are all fixed inside the carb. Other carbs have only the idle speed mixture screw that can be adjusted, like yours seems to have. Is this screw you mention at the top and completely outside of the carb to adjust the throttle? If it is it's probably the idle speed screw which can be adjusted to any idle speed you want and has nothing to do with the air fuel mixture but If it is right next to the idle mixture screw, it might be the high speed mixture screw but is capped so it can't be adjusted. The low and high speed mixture screws should be marked next to each screw H and L.
The 1 1/2 turns suggested is sometimes just right but other times has to be adjusted, so you can try adjusting it to get your idle but maybe adjust the idle speed screw first to get a higher RPM so it doesn't stall on you. Like I said earlier it just adjusts the throttle, and is like when you are using it, and giving it gas as they say. I hope this helps just a bit. Regards and good luck. Get back to me if you need more help or just let me know how you did. Denis.
2answers
Need to know best way to adjust carb to get maximum performance on my homelite XL12
Regarding the adjustment procedure you generally start your low and high mixture screws at one turn from seat, or slowly turn them in all the way until they bottom out and then back them out one full turn. You will adjust the high speed mixture screw at full throttle and get the median point between too rich (loads up) and too lean (dies out). You will want to do the same thing with the idle mixture screw, just adjust at idle rpm. You will also adjust the low idle mixture screw to give you a smooth transition from idle to throttle up. Once this is obtained, you adjust the third or idle speed screw low enough so the chain does not turn at idle rpm but high enough so the saw doesn't cut off. Hope this gets you going.
7helpful
2answers
Carb settings mixture jets on a homelite weedeater st155
ther is no set setting but to get it to run so it can be adjusted. lightly close the high off then open the low about two turns. try to start if starts slowly adust the low screw till it runs normal with the choke all the way off. then start to add throttle while turning the high out till regiured rpms ar reached with no misses. this takes awhile even fo a seasoned mech and may require several attempts
Dec 24, 2009 • Garden
2answers
I have a hb180 homelite leaf blower and want to know how to adjust the 'two' little screws on the side and what they do
if its the carb screws your talking about
one it for fule mixture the other is for air,,,
air for tickover fule mixture for rev's
if its running well leave them be?
Oct 30, 2009 • Garden
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
