For some reason all the lights are flashing on the dishwasher display and counting down. It happened once before and I was able to press the start button and hold it in and it cleared it, but that didn't work this time. It just keeps counting down over and over and I can't start it now.
Try pressing heated wash, heated dry, then heated wash, heated dry. It should reset it. Also try pressing and holding the cancel button for 5 seconds to see if that works if the other doesnt.
Tried the heated wash/heated dry sequence but no luck. Turned of power to dishwasher (300 series) for 5 secs and then turned power on and lights/count down stopped flashing/counting. This is the same procedure one does when your satelliite receiver hangs up.
I have a quietseries 400 I get a flashing L whe I press any button
SOURCE: Maytag 300 Litghts flash in sequence
Yes I think I was able to solve the problem. I'm not sure, but it appears to be working properly now. Since I was able to possibly solve the problem, if you want the answer, I would like to direct you to my Premium Assistance Plan. For $9.99 I will give you the answer, just like you offered me.
SOURCE: 1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
SOURCE: Maytag Quiet Series 300 Dishwasher will not turn off after it com
MY DISHWASHER KEEPS RUNNING, IT IS A WHIRLPOOL GOLD QUIET PARTNER IV
SOURCE: Maytag Quiet Series 300 owners manual
my dishwasher does not want to work anymore it has a big L flashing
Flashing L on dishwasher and nothing is working when I press the buttons.....
Can someone resolve this issue - all the display lights blink in a pattern and it counts down from 50. I checked the two door switches (good) and reseated the connectors. The have the quiet series 300 but the model number is different. MDBH970AWQ
i've tried all these suggestions and nothing is working. The "L" flashes on when I try to press any buttons (including Cancel) and holding down the Cancel for any length of time does not work. There is no "heated" wash cycle--just Heavy, Light, etc. cycles.
Lights blinking
