Please wait a moment error canon ir 400
SOURCE: canon ir 400 photocopier
What is the sub error code E805-" " -007 is is a blown fan and a blown fuse on the DC control. " " -002 could be a broken connection or pinched wire under the adf pillar on the right rear near the fixxing unit. If your have more info. on the code let us known..... Good luck
SOURCE: canon IR 400s serial number instalation
Do you have the Fiery Print controller with the printer ports on the rear left of the machine? The link for the driver is at www.usa.canon.com. Find office products>iR330/400 and the PCL drivers are there.
SOURCE: CANON IR 400 COPIER - ERROR - E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
SOURCE: e805 error in canon ir 400
E805 error code means failure of one of the many fans inside the copier. If there is not a dash with four numbers after the 805 code on the display, it is one of two fans - FM1 the transport bed fan or FM9 - the reversing fan just below the fuser assy. There are several checks that can be done but a too lengthy to be described. A tech maybe the best answer depending on your mechanical ability.
SOURCE: CANON IR 400 WEB ROLLER HOW IT IS FIXING.I WANT VIDEO FILE
That is a little question with a big answer. You first need to buy a web ($10-$30) and then replace the old one with it. This requires tools and if that appeals to you then I'll write the rest of this response, but it's a dirty job. The only tool you really need is a Phillips #2 screw driver. Else if this doesn't appeal to you then call a copier tech to do the job. Good luck either way.
Testimonial: "how to fixing the ir 400 web roller "
