When i start the laptop it automatically start printing * key. i am not able to do any work on my system. the key is getting pressed automatically. when i open word or notepad before i start typing, it automatically starts printing *(star). whether its a keyboard issue or some kind of virus. help me out.
SOURCE: T61 Laptop Keyboard Mouse Issue
ensure the trakpoint is enable in the thinkpad configuration utility
SOURCE: problem with the novo key.
Lenovo has a support site that you can go to, which I have linked to below. I have already narrowed down the pages so that you can scroll down to the keyboard section, and just click on the appropriate link. This will install drivers (basically what runs the novo key) that will fix your problem.
http://www-307.ibm.com/pc/support/site.wss/MIGR-68104.html
The correct driver should be located around the middle of the page or towards the bottom.
SOURCE: q key keps printing
Understand and use (or make sure they’re turned off) keyboard Accessibility Options. There are several types of help for those with typing difficulties, namely:
StickyKeys is an accessibility feature designed for people who have difficulty holding down two or more keys at a time. When a shortcut requires a key combination such as CTRL+P, StickyKeys will enable you to press one key at a time instead of pressing them simultaneously.
FilterKeys: You can set Windows to ignore keystrokes that occur in rapid succession, or keystrokes that are held down for several seconds unintentionally.
Bounce Keys: If you bounce your fingers on keys inadvertently, Bounce Keys will ignore repeated keystrokes until some time has passed. You choose the time period.
Repeat Keys and Slow Keys: The computer will ignore brief keystrokes according to the time limits you set.
To access these Options and turn them off or on, go to your Control Panel– click Start >Settings >Control Panel >Accessibility Options.
By default it opens to the keyboard tab. If you are experiencing a sudden onset of bizarre typing behavior, your first step is to visit here and ensure that there are no checks in the three checkboxes, which indicates these Options are in use.
I mentioned that shortcuts ‘activate’ these features — such as Tab+Enter, and a couple of Alt+a letter– and so you may have turned them on unintentionally.
If you do have some difficulty with your typing, such as happens when a Mr. Arthur Itis comes to visit, or/and if you have tremors, here is where you can enable these aids and tweak their settings to get the most benefit from them. Click on the “Settings” button to see the choices. Below is the FilterKeys Settings dialogue.
In the case mentioned, my client had first held down the Shift key long enough to activate FilterKeys (because a finger “rests” there). The lady was an extremely fast typist, and this setting ignored her strokes as being too short. Since she has no use for this tool, I recommended that she uncheck the top checkbox and disable the activating shortcut.
This screenshot shows the settings for StickyKeys, and unless you have trouble holding down more than one key at the same time — such as Ctrl+Alt+Del to activate Task Manager — I suggest you uncheck the top checkbox here as well.
SOURCE: key board problem
You have the numlock pressed. Look for its key in the top right, and change it so the display for numlock is turned off.
Testimonial: "yes. thank you so much!!! i reall aprrecaite.. it worked.. noever been so happy haha"
SOURCE: lenovo n500
you should call the lenovo warranty support hotline and check your warranty if you can sent it to the depot to be repair free of charge :)
try this lenovo hotline check if they support the model that your using if not they will transfer you to IBM 18774536686
