Jura Capresso Impressa E8 Espresso/Coffee Maker Logo
A
Anonymous Posted on Oct 07, 2013
Jura ena micro 9. no water passing out the spout when rinsing. Coffee comes through when making coffee.
2 Related Answers
espressonist
espressonist
  • 1711 Answers
  • Posted on Jan 09, 2011
SOURCE: when making cappucino coffee using
The problem
you describe it can occur if you don't perform the tablet cleaning as describe
in the user manual at page 30, (see link below).
http://www.capresso.com/pdf/inst_z5.pdf
The machine
changes the direction where the coffee will be delivered via a solenoid valve.
The coffee oils that remains inside this solenoid every time you make a coffee
they can dry out and after many coffees and if you don
Anonymous
  • Posted on Aug 29, 2011
SOURCE: Jura-Capresso Impressa Z5 - left coffee spout is
I had similar problem, Jura told to open a paper clip and push it up into the four holes on each spout. This worked the first time I had the problem. But now have one side not flowing again and the clip is not helping.
5helpful
How do I unblock the coffee spout of the jura 5
My Jura 5 was only pouring coffee from one spout, the other was blocked. I fixed it by removing the cover from the spout (see photo) it clips off with pressure applied to the sides on the dimpled part, then removing the brown reservoir inside after disconnecting the brown tube. Right enough, one side of the reservoir was full of coffee residue. I cleaned this with hot water and a tooth brush before re-assembling it all. The machine now pours perfectly from both spouts.
Jura ena micro 9 error 5
jura Ena micro 9 PROBLEM. CAN NOT POUR WATER WHEN MAKING COFFEE
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Grand Canyon Tech
Grand Canyon Tech
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
