Igia AT6758 Finally Gone Hair Removal Home Electrolysis Kit Logo
A
Anonymous Posted on Oct 08, 2013
Does anybody have a good hair removal kit? I have been trying to find something for my husband.
Isabella Bird
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 16, 2013
Isabella Bird
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
129
Points
You should try the MeSmooth. It is an awesome device I think your husband will like. It works with IPL which is Intense Pulsed Light and radio frequencies that get directed to the base of the follicle. Your husband will be able to adjust the settings, which gives him the ability to change what he needs for different parts of the body, based on sensitivity and the amount of hair in a given area. The system is more comfortable than anything on the market, which is unusual in my experience. It works with all skin tones, which is not the case with all the DIY permanent hair removal products. Lastly, it tends to be less expensive than similar products, which I found attractive. I have one and it is better than I ever imagined (and I have tried EVERYTHING). Cool gift btw.
My husband lifted a pot of water off the stove that tilted over and water spilled on burner. Now there is a constant clicking sound and when I look at each burner I can see the little sparks like it is...
I recommend unplugging the AC since this is stressing the high voltage transformer.
You need to gain access to the area under the top and thoroughly dry the area.
If you have as hair dryer or smaller heater, you might aim the hot air to areas around the burners.
Good luck-
My car won't start & has absolutly no power going to it!!
Maybe the engine isn't working right. If the model is old, it is probably just a break down. Did you go to a professional mechanic shop? That's something you need to check. If it's an old car, I guess you just have to move on to a new car, or used. Sorry about what your going through.
Can anyone recommend a good wax warming kit that I can use at home for hair removal?
I use the GIGI wax warmer as I found it really reasonable price wise and I think it does a good job. Amazon are selling it for around $22, see the link below;
http://www.amazon.com/GiGi-0225-Wax-Warmer/dp/B0030ZRS7A/ref=sr_1_2?s=beauty&ie=UTF8&qid=1352976928&sr=1-2&keywords=wax+warmers+kits
My husband is using bigen speedy for the past 8 months.now i want to know whether it cause any side effects
Many studies have been conducted to try to determine whether long-term hair dye use causes cancer, and it is still a controversial subject. Most studies have focused on a possible increased risk of bladder cancer. Some studies have found that women who had consistently used hair dye long term had higher levels, and other studies did not. Many official bodies have determined that the evidence so far is inconclusive.
However, new studies have linked hair dye use to development of a specific type of cancer,non-Hodgkin's lymphoma (Zhang et al, 2008). This study looked at groups of women suffering from this disease, and a control group. It was found that women who started using hair dye, particularly darker colors, before 1980 had an increased risk of developing the disease
2answers
Danze shower kit
your husband is 100% correct unless you change the shower head or take the one off that is there and take out the little plastic filter thats right inside where it screw on to the shower arm,, easy fix
2answers
Hydrogen-generator
If your engine is compatible(ford dealership should tell you)then LPG is the way to go.
Top Igia Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Igia Health and Beauty Expert? Answer questions, earn points and help others
