On my calculator how do i enter a pv and an fv and all the other tvm values
SOURCE: finding N value on Ba11 PLUS
You need to have your PV and your PMT be a different sign. Try making your payments negative.
SOURCE: Computing N in a TVM calculation (receive Error 5 message)
Hey,
Just found out the answer!
Apparently you can't have both FV and PV positive. Try the calculation with one of them being negative.
SOURCE: How to use my calculator
http://education.ti.com/educationportal/downloadcenter/SoftwareDetail.do?website=US&tabId=2&appId=6114
SOURCE: Calculating PV where n=5; i=6%; $18,400=pmt; 0=FV.
Check to make sure you have the proper value set for payments-per-year.
SOURCE: im am baffled. my ba-II plus is not calculating
It's giving you the correct answer for the problem you've input. When you specified 1 for n, you told it one month. If you specify more digits, you'll see that the answer is 1.00833333.
By default, the calculator works with annual interest rates but counts periods in months.
