My desktop pc came with Office Student. I purchased Off Pro because I needed publisher, etc. I can't seem to get Pro Off 2007 to run! I think it just installed anothjer copy of Office...?
Did you un install the student version first?
if not, got to start>>control panel>>add and remove program.
unistall both application and re install the por version.
restart the machine in between.
archive everything that you think or know you are going to need. including e-mail. e-mail may be a tough one to do. please post back if you need instruction for archive e-mail.
remove any of the office applications will destroy what you have setup, but not the content.
example: i fyou creat a document in word. and you unistall the word from your computer. the document you created using word will be in text format, you can open that with notepad or winword.
deleting Microsoft office will not affect any other applications. with exception of document or spreadsheet created with MS office suite. the document will be available after you have reinstalled the offcie suite.
go to the following link and download the "easy uninstaller"
and it a go.
Look in the Add/Remove programs applet of he Windows Control Panel to see if you have two copies of Office installed. If so, you may want to remove both and re-install the Pro copy only. If this is an upgrade you may need the original install media to prrove you are upgrading legitimately. You may also want to first try to make a "change" using setup to your existing copy if there is only one to add the application(s) you want from the upgrade.
Ok.. no I did not uninstall the Student Version because frankly, my husband uses Peach Tree accounting and I am so worried that I might mess that up! Will all of the other programs I have still work? And what about email addies, newsgroups, etc that we have in the Office apps- wil the be erased if I re-install Office Pro?
Ok, maybe I will try that. It's just that hius desktop pc isn't the one I use BUT just after we bought this and transferred our biz & accnt software, I tried the activaton assisstant and now when you try THAT to try to get Pro eunning, it opens word! Sadly Diagnostics says alls fine! and tis not~
Ok I am really panicked NOWm, guys! When I try to uninstall a window pop up says: Windows cannot find any available prodcucts to uninstall. Please contact your system adminstrator. Ummm last I knew *I* was that! now what? BTW- both student & pro icons are showing up on the add./remove programs window but BOTH have the same response when I try to uninstall or change.
