RIM BlackBerry Curve 8520 Smartphone Logo
abraham Posted on Oct 07, 2013
Can i change my password if yes how? - RIM BlackBerry Curve 8520 Smartphone
DemnZ
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Oct 19, 2013
DemnZ
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
8881
Points
33
There is password change option in menu . Just enter your old password and change it to new .
Did my password get changed
Yes, go to your account using new password.
  1. Visit the Change your password page.
  2. Type your current password and your new password.
  3. Click or touch Change password.
press the helpful button and check links below
Sign in security
Change your Google Account password
https://support.google.com/dartsignin/answer/114769?hl=en
Someone changed your password
4helpful
I forgot my yahoo password
Can you access Yahoo email ( if you had cookie set for password ) ? if Yes, go to account profile and change the password. use the same new password for Yahoo Messenger.
I want to uninstall my blue coat k9 with out using my password
Click "Start" and open your computer's "Control Panel."
Click "Add or Remove Programs."
3Select "Blue Coat K9 Web Protection" from the list that appears.
Click "Change/Remove." Click "Yes" to confirm.
Enter your K9 password and click "Uninstall."
Click "Yes" to reboot your computer when the process completes.
  • 2 Click "Add or Remove Programs."
  • 3 Select "Blue Coat K9 Web Protection" from the list that appears.
  • 4 Click "Change/Remove." Click "Yes" to confirm.
  • 5 Enter your K9 password and click "Uninstall."
  • 6 Click "Yes" to reboot your computer when the process completes.
  • Read more: How do I Uninstall K9 From the Local Computer? ' eHow.com http://www.ehow.com/how_6885359_do-uninstall-k9-local-computer_.html#ixzz1CpiGZfJL
    HOW DO YOU CHANGE THE PASSWORD ON THE MITEL 5220 IP
    1. Press SUPERKEY.
    2. Press the No softkey until "Set Password?" appears.
    3. Press the Yes softkey.
    4. Do one of the following:
    ?? To enter a new password, enter your password.
    ?? To change or clear your password, enter your current password.
    5. Press the Enter softkey.
    6. If you are changing or clearing your password, do one of the following:
    ?? To change your password, enter your new password and press the
    Enter softkey.
    ?? To clear your password, enter 0.
    7. Enter your new password again.
    8. If you are setting up or changing a password, press the Enter softkey.
    9. Press SUPERKEY.
    1helpful
    Can i change my facebook password
    yes. you can change your facebook password.
    login to your account then go to account > my account > password > click change then:
    type your old password, type your new password and type again your new password in the confirm password box then click change password. then you are done.
    2helpful
    I got a used ps2 slim and i cant watch friday cause the level has to be 8 how can i change the password
    I love that movie!! XD Yes, you can change the password. Here's how: 1. when asked if you want to play it, select 'yes'. 2. select 'yes' to change parental control level 3. important! if you don't know the passward, press 'select'. this takes you to the 'delete password' option. Enter '7444', then enter a new password. 'Register password' prompt appears. Re-enter new password and it should play the movie. This works on all PS2 models :D. NOTE: To ensure your new password is saved, you should EJECT the disc and then close the tray with the OPEN/CLOSE button BEFORE you POWER DOWN or RESET the PS2.
    Level change
    here it is:
    Step1
    Place a DVD that prompts you for your password in your PS2. If you have any R rated DVDs sitting around, one of those should work just fine. It should prompt you for the password before anything else comes up.
    Step2
    Select "Yes" to playing the movie and select "Yes" again to temporarily suspend parental controls. This is where you would put in the password if you knew it and the DVD would play. You may try "1111" at this point, as it is often the password. If that doesn't work, continue through the next few steps.
    Step3
    Press the "Select" button on the screen that wants you to input the password. This should change the text on the screen from "Enter Password" to "Delete Password."
    Step4
    Input the numbers "7444" into the box on the screen. This is the universal password needed to delete the current password. Once you input the numbers, you should get a message that says "Deletion Complete." Press the "Select" button again and you should be prompted to enter a new password.
    Step5
    Enter a new password for your parental control. Make sure it is something easy that you will remember. Once you enter it in, you will be asked to confirm your new password. Enter it one more time and you should be able to watch any DVD you want.
    if it helps please rate positvely!!
    Top RIM Cell Phones Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Kolbrun...
    k24674
    Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
