If the lights on a the throttle are showing a full battery then try disconnecting the brake switches at the controller one at a time. If the bike works after disconnecting a brake switch then that switch is faulty and should be replaced.
There is some excellent information on trouble shooting and testing components here http://www.razorama.com/razor-installation-guides.html
also wiring diagrams here http://manuals.monsterscooterparts.com/recreational/Razor/Wiring/
SOURCE: how do you get the tire of the rear rim of the
i would suggest taking the chain off of the sprocket(cog), then loosening the nuts. then using tire-levers from a bike shop to carefully leve-off the tire. this should work....i have experience with bicycles....i race them! good luck!!!
SOURCE: The MX500 wont start. The light says the battery
Although you alternator may be charging, the battery may not be accepting the charge or holding it. Have the battery tested under load, but I think that you are going to find you will need to replace it.
Testimonial: "Thanks for the quick feedback. I appreciate your help as I am a novice at this."
SOURCE: I picked up a bike
It sounds like the throttle cable needs to be adjusted/connected. Check all the cables/wires going to your throttle.
